Garage Door Area - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-12-2012, 04:46 PM   #1
Garage Door Area
hi,
I have 2 garage doors that have some gaps that I would like to close up and not have little bugs and critters come in and will also help keep some of the hot/cold air out.
Does anyone have recommendations to fill in the void? (Picture attached)
I thought about the foaming sealant but was afraid of the sticky mess.
Any thoughts? Cement repair or will that have a hard time sticking to the materials in the picture?
RitzLondon is offline   Reply With Quote
Old 11-13-2012, 08:02 PM   #2
http://www2.dupont.com/Caulk/en_US/p..._silicone.html
What about this product?
Old 11-17-2012, 06:05 PM   #3
anyone?????
Old 11-17-2012, 09:53 PM   #4
Rewards Points: 940
I don't see a gap there, I see some foam.
I guess the short little section of wall on top of the footing didn't come out far enough? So they extended the bottom plate and wall to where it needed to be, cantilevering over the concrete?
I guess what I would do is to cut a piece of concrete or concrete block or even brick to the size you need, then mortar it in there.
I think it will stay there. It will be sitting on the footing, so it should be ok. If the joint cracks, it will still stay where it is.
cleveman is offline   Reply With Quote
Old 11-19-2012, 06:36 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 660
Ayuh,.... Or just dig out the foam, 'n pack some motor/ grout in there, 'n purtty it up....
Old 11-29-2012, 02:59 PM   #6
Try using cement or gravel to seal off that end, i think it should work. Check it out here Alexandria Garage Door Company. Let me know what you think. Go to the repair page.
alexandria101 is offline   Reply With Quote
Old 12-04-2012, 03:39 PM   #7
Rewards Points: 254
I foamed mine, let it dry and trimmed it flat.
pwgsx is offline   Reply With Quote
Old 12-17-2012, 11:53 AM   #8
Which foam did you end up using?? Great Stuff?
If so, which one? http://greatstuff.dow.com/products/
Thank you very much!
Old 12-17-2012, 11:53 AM   #9
I went to the repair page, what am I suppose to be looking at???
Thanks!
Old 12-19-2012, 03:24 PM   #10
Rewards Points: 254
yep that stuff
Old 12-26-2012, 04:12 PM   #11
I would remove the foam and use concrete. Best permanent solution.
GreenBoyz is offline   Reply With Quote
Old 12-26-2012, 07:30 PM   #12
Rewards Points: 744
Thanks!
It's probably just a shameless attempt to promote his garage door business. Though, if someone's recommending gravel as a proper fix, I would run away.
Seattle2k is offline   Reply With Quote
Old 12-26-2012, 08:17 PM   #13
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,110
Foam works fine if it is not UV exposed.
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 10:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
