Garage Concrete Sealer - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-05-2014, 10:18 PM   #1
Rewards Points: 53
I have been reading about the two different types of sealers: penetrating and coating. I am wanting to protect my garage floor from oil soaking in to it. The penetrating looks pretty easy to apply, basically just spray it on. Does it work? DOes the coating epoxy work? Which brand should I go with?
tucker0104 is offline   Reply With Quote
Old 03-07-2014, 07:45 AM   #2
Rewards Points: 4,534
solvent-based sealers are more protective than water-based
Old 03-07-2014, 06:59 PM   #3
Rewards Points: 152
I have used different epoxy based floor coatings with consistent results. Valspar make a decent one. Cant comment on their sealer tho. GL
TRUEPRO is offline   Reply With Quote
Old 03-10-2014, 06:59 AM   #4
just bought a gal of sher-wms solvent-based clear conc sealer yesterday,,, don't like it BUT we're out of elitecrete's ' CSS ' which is the absolute BEST acrylic based solvent sealer avail [ no $ int ],,, be aware sealing can be an annual maint issue
all i can say is sher-wms could've been rolled on straight out of the can its that thin,,, CSS is 100% solids & must be applied 2X & diluted w/xylene for best results
sher-wms is probably just the same as valspar, apron, or vest store stuff but my discount's larger from sher-wms
Old 03-10-2014, 03:07 PM   #5
Rewards Points: 3,410
For what you want to use it for,use a polyurathane or epoxy as it forms a film on the surface of the concrete.
Canarywood1 is offline   Reply With Quote
Stamped concrete sealer question bjansa Concrete, Stone & Masonry 3 05-09-2013 10:55 AM
Concrete Driveway Sealer Questions sore thumb Concrete, Stone & Masonry 9 04-13-2013 06:33 PM
Concrete Sealer For Home Patio & Sidewalk JasonCA Concrete, Stone & Masonry 1 01-22-2013 03:28 AM
Removing part of a concrete garage tire stop? Lurch96 Concrete, Stone & Masonry 5 01-04-2013 09:59 PM
Concrete garage floor. Imessano Flooring 8 03-31-2012 06:01 PM
