Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-16-2012, 12:57 AM   #1
Gap in concrete by corner of garage door jamb, intentional or not?
I was pursuing actions of filling gaps in concrete per my earlier post:
Line spacer gaps in concrete driveway and sidewalks - ok to fill up gap?
and upon clearing up dirt debris off the gap between the concrete of garage (by the garage door) and the driveway concrete, noticed that there is quite a cavelike cavity of a gap in the concrete at the corners where the garage door jamb meets concrete. The cavities had some loose screws and pebbles, I assume left over during construction or remodeling by previous owners/workers that settled there. The walls of the cavities are concrete with the top being the wooden door jamb. Cavity is a little smaller than size of a kiwi, and was orignally covered up with dirt/debris, so you wouldn't notice the hole.
Photo is attached.
I ended up filling up the cavity with concrete gap/crack filler. But thought I should post here asking if it should have been left open for ventillaton or expansion/contraction of concrete and soil.
And also to ask whether that gap is bad design when concrete was poured or whether it was intentionally left there to assist with installing/removing door jamb?
Gap in concrete by corner of garage door jamb, intentional or not?-garagedoorcorner.jpg
daluu is offline   Reply With Quote
Old 09-16-2012, 06:23 PM   #2
World's Tallest Midget
Mort's Avatar
I wonder if it was originally for a downspout?
Mort is offline   Reply With Quote
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage concrete block foundation on slope gopherdad Building & Construction 3 07-30-2011 02:23 PM
How to fill in large hole under the corner of garage? willfixsoon Building & Construction 1 09-29-2010 05:39 PM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
