Freestanding Deck With Water In The Holes. HHHEEEELLLPPP - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-12-2012, 04:35 PM   #1
Question
Freestanding deck with water in the holes. HHHEEEELLLPPP
I have been reading many threads on this site and many others and I have not come up with a solution to my problem. I decided to build a freestanding deck. It is going to be placed about 8 feet above ground level. The dimensions of the deck will be 16' wide and 12' out off the house. I placed my outer posts at 11' and my posts closets to the house are 2'.
I began to dig the holes closest to the house to code depth which is 36". At 2 feet down I started to see water. I kept digging expecting to find more solid ground. The deeper I dig the softer the earth gets. I used a shop vac to clear it and the water keeps returning to the holes. We haven't had rain in about a week. I marked the holes and the water keeps filling up to that level, about 1 foot. The holes I dug at 11' off the house were dry. Not a drop of moisture.
My house is brick veneer so I am very hesitant to do a ledger board attached to the house. I have already dug 44" inches and I am still getting the sloppy mud. Any ideas? I thought about running the posts right against the house, setting them on the house footing and anchoring them to the foundation. The other option might be to bring the deck height down about 7 inches build a step down. Could I put a ledger on brick that has hollow core block behind it? Do I need a french drain? My front yard is higher than the back yard. I have had people tell me to let the holes dry up. I have been shop vacing them out constantly for the past 4 days and there is no sign of drying up. I have heard just dump a dry bag of cement in there. The holes fill up rather quickly. I am getting about 6 inches of water every couple hours. The water levels off at about 1 foot. I feel like building on this ground is unstable. Please someone help..Too many sleepless nights for this guy!!!
bassheadjohn is offline   Reply With Quote
Old 08-12-2012, 05:28 PM   #2
Too Short? Cut it Again!
When I built decks, pergolas and things in Foster City, CA (built totally on semi-solid landfill) we literally had to have a tide chart handy as holes would fill up at high tide. A friend married the woman from Foster City but when they were dating he needed a tide chart to get in her apartment as the door would not open until the tide went out again.
It sounds like you may be sitting on some sort of artesian well or aquafore situation. You might check with PA water survey folks? They should have charts of the overall water situation near you. There may be restrictions on what you can do to alleviate your current situation. Are you near the river at all, by the way? Are you flood prone? Nothing in your title documents?
I suppose it could be a slow leak in plumbing somewhere but your water bill should reflect that. Are your downspouts draining into clay or pvc pipe. It could be leaking. Here we can drain them that way because of the load on the sewer.
Old 08-12-2012, 08:33 PM   #3
To reply to your comment. There aren't any streams on water within miles of where I live. The downspouts discharge into the yard and gutters are at a questionable height below the roof line. I plan on re-routing them and discharging them as far away from the house as possible. The water that is collecting in the holes is very clear looking and has no smell to it. I am doubting it has anything to do with sewage. As far as a leak in the water line,my supply enters in from the opposite end of the house and bills seem to be normal.
Old 08-12-2012, 08:40 PM   #4
DIY staff
Rewards Points: 7,174
Be patient--we have some concrete guys here that may look in---
I do find it odd that the far holes are dry and the near in ones are wet--
How old is the house--any chance of an old cistern or leach lines that are abandoned?
City sewer and water?
user1007 (08-12-2012)
Old 08-12-2012, 08:42 PM   #5
Talked to a cement guy today...
I talked with a cement guy that was a foreman with a rather large company in this area. He mentioned there could be a number of possibilities that the water is there and at different levels in the holes. He made the following suggests and thoughts.
1. Mark the height of the water.
2. Clear out as much water as I can.
3. Toss in a shovel or two of gravel and hand level.
4. Run rebar horizontal across the hole and into the earth a few inches. This would stabilize hopefully eliminate the concrete from wanting to fall or rise.
5. Vac out any water that appears to may have risen above the gravel.
6. Toss in a "tight" (dry) mix of concrete into the hole.
7. Add concrete to about 4 inches above the water level.
His theory is that water will level itself. With the concrete present the water will go somewhere else and level out.
Seems valid But to me it still feels like a gamble.
Old 08-12-2012, 08:46 PM   #6
Reply to Oh'Mike.
The house was built in 1958. Only thing that I know that is questionable it terra-cotta lines that are nearby. I had a plumber put in a considerable amount of dye into my drains and I haven't touched the holes in 2 days. The water levels out to the same height and no dye..yet. Of course it might take some time to move through soil.
Old 08-12-2012, 10:08 PM   #7
Me too and it could come back to haunt you and perhaps in a costly way. You should find out what is happening and not just rely on water to find low ground. If you start dumping dry mix in the holes you may find you just have to dig it out in short order.
Among other things if it is something you have to dig to resolve it would be a shame to get your deck built only to have to pull it apart?
Hadn't thought of a cistern but have certainly encountered enough of them to know they can create problems if they are not filled in. You may need a permit to fill one in though, especially if there is any chance of leaching into a drinking water supply, stream or river.
Old 08-13-2012, 08:00 AM   #8
Cistern free
I am real sure there isnt a cistern under or nrar the house. I am ruling that out. I woke up today thinking i need to figure out where this water is coming from. If it is a spring near that i disturbed enough soil to free up some water can i build on it? If it is a spring wouldnt the hole continue to rise and not level off? I may concentrate on my downspout dischsrge and gutters a little while. I may have this terra-cotta looked at. I am still scratching my head over this and still have a door to nowhere. With a growing family we are probably going to sell in the next year or so once i finish my projects to bring more value to the house. I am pretty sure a door to nowhere will not yield positive results at selling time.
Old 08-13-2012, 08:16 AM   #9
DIY staff
Tell us more about the house--age and plumbing---
A picture would help--
Also--if you have a leak in the main incoming water line--and the meter is inside the house--your meter would not register the leak.
Do you have perimeter weeping tiles and a sump pump?
Basement or crawl space? The dry holes away from the house make me think the water is coming from the house systems--not ground water---post pictures.
Old 08-13-2012, 08:44 AM   #10
AHH, SPANS!!!
Rewards Points: 1,166
I've run into that a few times and it was usually the foundation drain for the house releasing water that just sits in the drain.Some foundation drains do not drain well so water basically sits in the drain beds in some cases and when digging near the drain the water finds the new hole. If the backside of the house has lower grade than the front that could be why it is taking so long for the pressure to relieve itself. I have run into springs under houses too with crawfish and everything.
As the concrete guy mentioned, if the water level remains constant then you should be able to work with it with gravel and what not
hand drive is offline   Reply With Quote
Old 08-13-2012, 09:53 AM   #11
Picutres
I will provide pictures later this evening. The house is a 1958 ranch house with a basement. I do not believe there are an exterior french drains. Definitely no sump pump, no crawl space. The house is built on a footer with a block wall foundation. The basement is your standard concrete floor/slab. The front of the house the ground is level with the top floor. The rear of the house the ground is level with the basement, a floor lower. My water enters the house from the street opposite from where I am working. All lines in the house are above ground. Sewage drains towards the street opposite where I am working. I am going to have the drain near where I am working inspected. Its a tough $250 but may answer some questions here. I will take some pictures today and post later this evening.
The Following User Says Thank You to bassheadjohn For This Useful Post:
oh'mike (08-13-2012)
Old 08-13-2012, 09:41 PM   #12
Pctures set 1
Here is a set of pictures of the layout of the land that I am dealing with. Most have labels. More to follow...
Freestanding deck with water in the holes. HHHEEEELLLPPP-streetview.jpg   Freestanding deck with water in the holes. HHHEEEELLLPPP-rightback.jpg   Freestanding deck with water in the holes. HHHEEEELLLPPP-backview.jpg   Freestanding deck with water in the holes. HHHEEEELLLPPP-backview2.jpg   Freestanding deck with water in the holes. HHHEEEELLLPPP-backview3.jpg
Old 08-13-2012, 09:49 PM   #13
Picture Set 2
Here are the rest of the pictures. This gives you a little idea about terrain and details about the house. The house sits pretty much on the top of a hill. As you can see I am working on the back portion of the house. Interestingly today I decided to clear one of the holes that had a questionable gray water enter I got a bunch of what seems to be sewage that oozed into the hole. I believe I have a brown terra-cotta under there. It seemed to tunnel back towards the house. There is some plumbing just behind the wall. It explains a little. I still am wondering why all the water is there...I am currently working on removing gutter covers that seem to send more water over the edges than catch it. I am also going to run the discharge of the downspouts back and over the rear hill of the yard. That should help with some of the ground water. This may correct the problem this may not. Until these holes dry up PLEASE continue to offer suggestions.
Freestanding deck with water in the holes. HHHEEEELLLPPP-sludge-1.jpg   Freestanding deck with water in the holes. HHHEEEELLLPPP-sludge2-copy.jpg
Old 08-13-2012, 09:51 PM   #14
missed 1
This is the last picture. this sludge re-appeared a few minutes after using a shopvac in the hole. Who knows how much of this is under there.
Old 08-14-2012, 08:55 AM   #15
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
OK, I admit I'm blonde and this is waaaaay out of my experience, but would it be possible to take a sample and have it tested for chlorine. If so, it would at least tell you if this is coming from the house or natural.
Tags
deck , freestanding deck , problems , water in hole
Refinished deck, now there is standing water.... noahd33 General DIY Discussions 6 08-28-2013 07:39 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Deck footing below water table! flyultralite Building & Construction 7 04-06-2007 10:18 AM
