Framing To Do Pan Decking For A Raised Porch. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-17-2012, 11:56 PM   #1
framing to do pan decking for a raised porch.
I have a 17'x8' front porch, which has a room underneath. I would like to raise the roof and replace the wood with concrete/metal decking, (pan decking). I want to re-frame with new wood supports underneath. Im just looking for the best way to make sure this is properly framed. Anyone got idea or even better a drawing? thank you for any input.
rookie68 is offline   Reply With Quote
Old 05-18-2012, 07:38 AM   #2
DIY staff
Rewards Points: 7,174
Some pictures will be needed to get a good suggestion
rookie68 (06-07-2012)
Old 05-18-2012, 09:43 PM   #3
Rewards Points: 3,422
Do you have pan decking at your disposal,and have you done this type of deck before?
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 05-21-2012, 12:28 PM   #4
Rewards Points: 152
The galvanized pan insert will need some block piers underneath for support. Those piers will also need a footer.
GL
TRUEPRO is offline   Reply With Quote
The Following User Says Thank You to TRUEPRO For This Useful Post:
Old 06-07-2012, 10:03 PM   #5
reply
No, i havent done pan decking before.. but ive researched this and it seems the way to go. I dont want to have to deal with replacing anymore wood(and i really dont want that compsite decking.) Thanks guys for the suggestions.
Old 06-08-2012, 12:22 AM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
This is something that is way beyond any residential codes I am aware of.
If you intend to get permits for this in order for you to cover your derriere, I doubt your local Building authority would sign off on anything that is not designed by a licensed engineer.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 06-08-2012, 11:24 AM   #7
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Gee, I've never seen pan decking on anything other than a multi-story steel framed building. I don't think a wood frame would work with it. I may be missing something here, maybe someone could correct me.
I hate signatures.
Mort is online now   Reply With Quote
Old 06-08-2012, 12:54 PM   #8
All the public parking garages i've ever been in are pan decks.
Old 06-08-2012, 01:32 PM   #9
Mort's Avatar
Rewards Points: 690
Oh yeah, that too. Not any residential decks, though.
I hate signatures.
Old 06-08-2012, 02:26 PM   #10
No not in my 35 years in the business.
Pre-planning: converting front room back to porch WillK Building & Construction 3 11-06-2011 01:47 PM
Fastening ends of porch decking w/out compromising flashing danf26 Building & Construction 1 09-08-2011 06:58 PM
Porch has shifted on a house I am considering buying. Need advice ryanclemson Building & Construction 4 01-31-2011 09:30 PM
How to rebuild a porch with a roof? redblotoflife Carpentry 2 11-23-2009 05:35 AM
Framing in New Windows to enclose a porch DDRowe Building & Construction 2 05-25-2005 08:05 PM
