Foundation Wall Leak Where Main Enters House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-08-2013, 06:53 PM   #1
Rewards Points: 187
Foundation Wall Leak where Main Enters House
Hi Everyone,
I'm not sure where to post this question, figured I'll try here first. After a lot of rain last night the ground was fully saturated and I noticed water penetrating my foundation around where my water main pipe enters the house. I'm preparing to finish my basement and obviously want things water tight. Do I need to excavate to the outside and seal, or is there anything else I can do? Someone recommended using a liquid concrete or epoxy from inside the basement, but I don't see how that would work if applied from the interior. Does anyone have any suggestions/recommendations? Thank you
Jim Ignatowski is offline   Reply With Quote
Old 06-08-2013, 09:02 PM   #2
MarginallyQualified
Rewards Points: 2,464
[QUOTE=Jim Ignatowski;1197633]
I noticed water penetrating my foundation was around where my water main pipe enters the house. ... Do I need to excavate to the outside and seal ... ?
Swag number: in 90% of the cases... nothing else is gonna do it.
Someone recommended using a liquid concrete or epoxy from inside...
Never used or seen it. Does this someone have more detail?
Old 06-08-2013, 09:28 PM   #3
Old School
Willie T's Avatar
I imagine anything is going to have to be done where the water first enters... outside.
Willie T
Old 06-08-2013, 11:13 PM   #4
Rewards Points: 4,452
it seems ' epoxy ' has become kind of a generic name for all sorts of exotic stuff,,, we use polurethane grout to seal cracks in conc & leaking utility penetrations,,, ck w/any const supply house ( NO, that doesn't mean an apron/vest store ),,, you should be able to get a tube for under $ 40 + the cost of the injection gun ( roughly $ 130 ),,, OR you might try hydraulic cement which may work well
Old 06-09-2013, 12:10 AM   #5
Rewards Points: 187
Thank you for the suggestion. Is this applied from the interior wall? I had someone else suggest hydraulic cement. Do you have a preference between the two? Since the leak is coming from around the water main pipe, there isn't much of a gap to inject anything.
Old 06-09-2013, 06:33 AM   #6
there are 2 recognized ways to resolve this problem,,, dig & patch OUTSIDE or patch/inject inside - that's it ! there airn't no mo'
my preference is polyurethane grout injection 'cause we make good $$$ from it we can iject crks down to .002" so i would worry about a penetration
your preferencs might be hydraulic cement 'cause 5# is only $ 12 - $ 14 + a margin trowel,,, makes more sense to me IF i were in your shoes
Old 06-09-2013, 08:59 AM   #7
Rewards Points: 187
Thanks again. Any chance the expansion of either of these materials would impact the water main pipe? I'm actually considering purchasing the injector as the opening around the pipe is barely noticeable.
Old 06-09-2013, 11:45 AM   #8
Rewards Points: 3,352
No neither one will impact the pipe,and since the opening is that small,i'd agree with your choice of injection.
Canarywood1 is offline   Reply With Quote
Tags
concrete sealant , foundation wall , leak
water main coming into the house? USNrider Plumbing 11 04-15-2013 07:04 AM
New House, new problems. need Wall Answers MerrittHII Building & Construction 0 03-06-2011 09:55 PM
Buying a house with foundation issue nhoc6131 Building & Construction 6 12-29-2010 11:18 PM
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 06:07 PM
Water in crawlspace, dug out too close to foundation, How to fix? Build a wall? twilightcall Building & Construction 6 05-18-2009 10:16 AM
