Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-07-2012, 01:53 PM   #1
foundation slope
Hi Everyone,
I have recently removed a lot of soil that was touching my siding shingles only to find a 4 foot patch of foundation sloping towards the house. One section of concrete has a very pronounced slope to it. It almost looks like a french drain type of thing but I have no idea if it was intentional or just poor work. House is over 100 years old. I'm the one who put the soil up to the shingles 12 years ago when i bought the house. All i knew at that time was that the land should slope away from the foundation so i tried to achieve that not knowing that i would cause my siding and some of the original wood trim board to rot. I'm wondering what i should do. Is this a problem? I am replacing some of the shingles and going to keep the soil away from them. Should i put some kind of metal flashing in there to direct water way out and over this concrete that slopes inwards. Pics attached. thank you.
Linda
foundation slope-foundation-slopes1.jpg   foundation slope-foundation-slopes2.jpg
rigpa is offline   Reply With Quote
Old 03-07-2012, 02:00 PM   #2
foundation slope
let me also add, that when i poked around the house foundation with a screwdriver i am touching concrete, but i don't know how many inches or centimeters before the wood sill starts. i'd say about one inch that i know of, maybe more.
Old 03-07-2012, 02:01 PM   #3
Civil Engineer
foundation slope
That looks like it might have been part of an abandoned project, hard to say. And those look like asbestos/cement shingles. If so, they are not going to rot from soil touching them, which is completely different than wooden shingles. You are right to have the ground slope away from your house, if those shingles are asbestos cement, I would put the soil back, the alternative is a fair amount of grading and some jackhammering to remove the offending portion of the concrete.
Old 03-07-2012, 02:22 PM   #4
foundation slope
Indeed they are asbestos shingles. I've attached some more pics of the siding deteriorating due to moisture i suppose. Those shingles are on the other side of the house, but kind of how the ones exposed to the soil looked too. Also a pic of the wood trim underneath the siding rotting. That section had been exposed for some time due to the siding being broken there.
so, an abandoned project? could the foundation have been poured like this originally? would jackhammering this concrete to level it compromise the rest of the foundation?
thanks again.
Linda
Old 03-07-2012, 02:23 PM   #5
foundation slope
the wood trim board rotting pic
Old 03-07-2012, 03:00 PM   #6
joed's Avatar
foundation slope
I question whether is is part of the house foundation or remnants of something else. Is there a basement or do you think this is a footing that the house was built on?
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-07-2012, 03:35 PM   #7
foundation slope
There is a crawl space under here, concrete poured foundation.
Question about slope of garage slab foundation pttcc Building & Construction 23 01-18-2012 11:57 PM
too much slope on slab foundation site ugabulldog Building & Construction 4 08-26-2011 12:09 PM
Garage concrete block foundation on slope gopherdad Building & Construction 3 07-30-2011 02:23 PM
rough estimate of foundation on slope billv Building & Construction 4 07-20-2010 10:12 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
