Foundation Leak Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-30-2013, 01:08 PM   #1
Rewards Points: 141
Need help with a leak, Need a best advise or quick way to stop water leak coming threw the foundation . The power to the well and well water coming into the house it's where it's leaking! The leaks are about 4 feet below the frost line and will not be able to dig it out until spring or summer .
And I do have one crack below a window sill that is also sprung a leak and was planning on a DIY low pressure hydro epoxy repair kit , has any one use these will it work with hair line cracks?
bote110 is offline   Reply With Quote
Old 12-30-2013, 04:43 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by bote110 View Post
Need a best advise... to stop water leak coming threw the foundation .
...about 4 feet below the frost line and will not be able to dig it out until spring or summer .
When you can... dig in there.
Pack the hole and then coat the wall.
Old 12-30-2013, 05:11 PM   #3
Rewards Points: 626
wow! not a easy fix persay, Were are located? sure you don't have a broken water line? if it were me I would be getting a back hoe and digging it up and running a french drain around my home. then drying the inside of the foundation wall. put some hydroban on it two coats and your problem is solved.
Nailbags is offline   Reply With Quote
Old 12-30-2013, 05:38 PM   #4
Rewards Points: 141
The back yard needs to be graded away fro the house ,so I need to get more fill . My sump pump has not come on and it's a couple of feet away from the puddle of water to the right. I don't think the holes were patch right from the outside! What would be best to patch from the inside , summer time going to have to patch from the outside before I build our patio witch will be right above it , I got a french drain under the slab {floor} .
What is the best way to pack there is a pvc pipe where the power line and water line runs threw ?
Old 12-30-2013, 05:39 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,066
Ayuh,.... I agree,... Foundation leak fixes usually start Outside the house,...
Old 01-01-2014, 05:34 AM   #6
Rewards Points: 4,586
IF you had noted your location as forum asked, it would make things MUCH easier on responders,,, no, its not too late to dig - more difficult perhaps if there's 5' of frost but not impossible,,, doesn't look as if the problem started just the other day so either live w/it til the ground thaws or,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
emecole is diy friendly altho I suspect their patience is often tested either dig outside & seal properly OR seal from the inside w/hydrophobic or hydrophyllic polyurethane grout,,, we've had luck sealing crks down to about .003" wide,,, doubtful we'd use it on the crk's windowsill.
[ no $ interest ]
Old 01-01-2014, 12:15 PM   #7
Rewards Points: 141
Yes I'm planning on waiting in the spring time to dig outside but I thing I need to dig that foam on the right side and pack both with dry hydrophobic as much as I can the patch with wet hydrophobic polyurethane grout. You think that will work? The other crack bellow the window sill is a settling crack that sprung a leak like 3 feet down It's only a pin hole but would like to seal it also with a kit like this :
http://www.bestmaterials.com/detail.aspx?ID=20052
what do you think?
Old 01-01-2014, 01:25 PM   #8
Rewards Points: 6,652
Really depending on where you are, and how cold it has been, the ground may still be warm enough, you can get it done now, then waiting for the Spring to roll around.
You can always build a tent to place heaters under, so that the space is warm and dry.
Old 01-01-2014, 02:10 PM   #9
Concrete & Masonry
Rewards Points: 548
For a hairline leaking crack, a kit like in the link may work. I've tried similar professional epoxies with varying results.
For the two bigger holes, remove all the "Great Stuff" and try something like this:
http://www.euclidchemical.com/produc...84&pselect=184
Obviously, the best bet would be to dig outside, but there's no need to do so now if these approaches work for now.............
jomama45 is offline   Reply With Quote
Old 01-02-2014, 03:48 AM   #10
' pack w/hydrophobic ' ? patch ? no, its injected into the crk 1/2 inside the wall thru a crk-intersection drilled hole OR, sometimes, directly into a sealed crk,,, that's why emecole suggestion - euclid's good stuff & we've used it, too,,, nevertheless, emecole's more diy friendly.
what do i think ? already posted response - you asked the ? so my answer should be obvious
foundation joint-concrete floor crack repair? s002wjh Remodeling 3 01-12-2012 09:33 PM
Basement foundation wall repair? ronnoez Building & Construction 8 12-06-2011 11:05 AM
Foundation Repair Yankees Building & Construction 1 08-28-2011 02:16 PM
Old Stone Foundation Repair - Sister Wall? Lime? tcook555 Building & Construction 1 08-26-2011 11:33 AM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
