Foundation And Footing Problems - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-04-2012, 06:16 PM   #1
foundation and footing problems
how big of a deal are cracks in a cmu block foundation and a crack in the footing? i really like a house that im looking at, but i noticed that it has these problems in the crawl space. just wanted to know if it was still worth considering. thanks
garrett reite is offline   Reply With Quote
Old 07-04-2012, 06:29 PM   #2
Rewards Points: 13,994
If your that interested hire an engineer to come take a look at it.
It could be the best money you ever spent if it ends up saving you thouands of dollars in repairs.
If a foundation is bad then the rest of the house will follow.
Old 07-05-2012, 09:56 AM   #3
Rewards Points: 502
As a very - repeat VERY - rough guide, if cracks are vertical and of fairly even width end-to-end, and not too wide, it's probably just shrinkage cracking (concrete blocks are well-known for this).
If the width of a vertical crack varies, and is noticeably wider at one end than the other, then you could well have problems as it suggests uneven and possibly continuing settlement of the foundation.
tony.g is offline   Reply With Quote
Old 07-06-2012, 05:46 PM   #4
Rewards Points: 152
This house wont even pass inspection with a sever issue like foundation failure. You need to get an estimate from several different foundation repair companies and present this to the seller in order to take it off the asking price.
GL
TRUEPRO is offline   Reply With Quote
Old 07-11-2012, 10:17 AM   #5
Architect
Rewards Points: 150
Concrete cracking is typical and expected in some cases, and could be an indication of failure or a larger problem.
Its probably best to post some pictures here first and we can provide better direction.
jcarlilesiu is offline   Reply With Quote
Ranch Porch Foundation and Footing VDB Building & Construction 1 06-04-2012 09:10 PM
Foundation and footing cracks willk53 Building & Construction 5 04-22-2011 08:46 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 10:17 PM
