Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-22-2012, 11:18 AM   #1
RCDD
Foundation crack repair
Good morning all. I have a crack in my basement foundation wall that was repaired before we moved in. It looks like they used a epoxy injection type system. The problem is it is leaking water in a few areas of the crack again. Is there an easy way of "opening" the crack back up and using the same product or maybe the poylurethane product instead of the epoxy? I tried searching the site first but didn't have any luck. Thank you all in advance.
dannykapp is offline   Reply With Quote
Old 10-22-2012, 11:26 AM   #2
May be more effective to do the repair from the outside not the inside.
Working gutters, grade running away from the foundation, no mulch piled up againt the foundation, no flower beds forming ponds.
May even need a french drain.
The key is to prevent the water from getting to the foundation in the first place.
Fieldstone foundation repair question fieldstone Building & Construction 1 06-16-2011 12:02 PM
Crawlspace foundation repair bmrsnr Building & Construction 12 01-20-2011 10:21 AM
crack repair help beerdog Drywall & Plaster 6 02-07-2010 05:38 PM
Ceiling Crack Repair Speckert Building & Construction 7 12-29-2008 11:03 AM
vertical crack on pour foundation, water leaking baseballfan Building & Construction 27 09-20-2008 10:34 PM
