Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-19-2013, 03:02 PM   #1
Foundation
The back of my house has like a 2 ft over hang except for 15 ft at end which is my dining room. I wanted to build foundation out of cinder block after I pour footing so I can extend that one room out 2 ft n make it even with rest of house. 1)Can I use cinder blocks on top of footing?
2) do I just rest my support beams directly on top of blocks when I build up my wall or should I put wood under my beams
ecocco1469 is offline   Reply With Quote
Old 02-20-2013, 05:56 AM   #2
Rewards Points: 4,642
WOW, didn't know anyone even made cinder blocks anymore you know the footing must be @ the proper depth for your location per local bldg codes,,, why not do it the right way - bld the fnd to proper elevation, place sill seal & sill plate, then frame the bumpout ?
a cheaper alternate would use conc blocks & fill cells w/grout but you still need a conc fnd
Old 02-20-2013, 06:06 PM   #3
I'm going to put seal foam n seal plate also after I full holes with concrete the reason I wanted to use cinder blocks was because I can not get cement truck in back with out ripping my fence. I am digging out to same depth as my foundation n putting down the cement pad. N wanted to know best way to build up my walls n if I could use cinder blocks n filling up holes with concrete as I go. I will also b using re bar as I build up wall
Old 02-20-2013, 06:12 PM   #4
Rewards Points: 13,712
Post a picture.
There's no such thing as "cinder block" any more. It's concrete block.
Old 02-20-2013, 07:01 PM   #5
even using conc block, you need to consider proper wall wtrproofing ( NOT dampproofing per bldg code rqmts ),,, we use roofing cement scrubb'd on w/long handle'd brush,,, ixnay on the roller(s),,, fill w/grout, NOT conc,,, they do make georgia buggies to carry conc from mix trk to pour site - rent 1,,, # 5 rebar 4 o/c stuck into the wet conc footer & bend an ' L ' into the btm of the vert rebar,,, & STOP w/the ' cinder block ' verbage - you can't buy 'em anymore
Foundation wall project and spread footings WillK Building & Construction 0 08-31-2011 12:46 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 02:51 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
