Found Cheap Concrete "tiles" With Metal Bars- What Are They? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-29-2014, 01:28 AM   #1
Rewards Points: 209
Found cheap concrete "tiles" with metal bars- What are they?
Hi I found a bunch of concrete stone-looking tiles. They're about 3/4 of an inch thick and about 1'x2'
They are solid, HEAVY and have metal bars attached to the end.
I figure they were for a faux solid stone brick entrance or something? Maybe the metal is for hangng them? OR they metal also makes them into a raised patio, so if I put them over concrete or a wood deck, it would make it seem like a stone-brick patio? Not sure.
Anyways I was thinking of using them for landscaping. I was thinking of using a decomposed granite path and using these as stepping stones in between. As far as that, what would you recommend for a base? Gravel then Sand?
I got it from the local Habitat Humanity ReStore which is like a salvation army or goodwill for home improvement.
crayola110 is offline   Reply With Quote
Old 03-29-2014, 07:09 AM   #2
Rewards Points: 236
i would think they are for hanging. especially in seismic cali
Fix'n it is offline   Reply With Quote
Old 03-29-2014, 03:01 PM   #3
Rewards Points: 209
Oh ok. Yeah I was thinking something like that. Either way it was reallll cheap for stones that I believe will be good for landscaping
Any have recommendation on thiese sorts of "tiles" for making a little walk way and small patio outside?
Old 03-30-2014, 09:47 AM   #4
Rewards Points: 236
yeah. put a good base under them. or they will start walking all other the placce.
The Following User Says Thank You to Fix'n it For This Useful Post:
crayola110 (03-30-2014)
Hanging Ballet Bars (commercial environment) in metal studs 504branchie Carpentry 12 03-29-2011 08:45 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
Help needed on Tiny Bugs found on concrete wall ngchunleng Pest Control 5 11-23-2008 12:08 AM
Repairing Futon metal bars? mikehende General DIY Discussions 9 01-24-2008 09:04 AM
