Footings Deck 10 X10 Foot About 4ft Off Ground. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-13-2012, 06:45 PM   #1
footings deck 10 x10 foot about 4ft off ground.
I just built a deck and used 8 inch sons tubes with 4x4 post. The inspector says I need 12 inch . I live in south jersey is this correct/
jimslic is offline   Reply With Quote
Old 08-13-2012, 08:14 PM   #2
Rewards Points: 3,624
More than likely the inspector is right.
Canarywood1 is offline   Reply With Quote
Old 08-13-2012, 08:14 PM   #3
Thread killer
Rewards Points: 272
What code are you using? Everything I've read says NJ adopted the 2009 awc for decks. Their footings are considerably larger than 12 inches and 6x6 posts
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 08-13-2012, 08:37 PM   #4
2009 codes thanks I should know the inspector is always right
Old 08-13-2012, 09:00 PM   #5
Civil Engineer
Rewards Points: 4,770
You probably should discuss all the issues the inspector has with your deck before you fix one issue, then he brings up others. I am guessing you did not file a plan first with the inspector, else he would have flagged the footing size, and the undersized 4x4's. Assuming there was no plan, there could be other issues such as inadequate size of framing members, improper brackets, inadequate railings etc. Might as well get them all out first rather than doing them one by one later.
Old 08-14-2012, 10:24 AM   #6
robertcdf's Avatar
I think the permit and plans would show that... Oh wait... That's why you always get the permit IN HAND before you start the project...
robertcdf is offline   Reply With Quote
Deck without ground support Orest Building & Construction 8 05-30-2012 02:32 AM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Help with deck footings Richo Building & Construction 3 06-28-2011 09:08 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Concrete Deck Footings Bumpy Melanie337 Building & Construction 6 09-24-2007 08:11 PM
