Footing For Deck Posts - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-24-2012, 07:30 AM   #1
footing for deck posts
Hey,
hope someone can help with this questions. We hired a contractor to do an addition ( against my better judgement, id usualy do this myself).
the augered 9 36" holes well below frost line for 6x6 posts. The plan all along was to pour footings and piers and install the post w/ simpson strong ties above grade.
first thing that went awry unknown to me was the guy put in just a few inches of bagged concrete....was suppose to be for the footing. I didn't like that and told them the footing needed to be 8".
So, they call a truck and poured 8+ inches of concrete in each hole.
two questions on this:
1) is there a problem pouring over the bagged concrete stuff initially put in each post hole?
2) it got damn cold after they poured these footings..low 20s. I checked several hours after pouring and didn't seem to be froze, then I put some straw over it. This was the first cold snap, so the ground is still pretty warm. Will this cause a problem?
backwaterdogs is offline   Reply With Quote
Old 11-24-2012, 07:35 AM   #2
Rewards Points: 14,312
Start by going back and adding where you live to your profile please.
Makes a big differance where you live on some questions.
Old 11-24-2012, 07:38 AM   #3
oops, sorry bout that...I'm in central Illinois....Peoria, IL. thanks!
Old 11-24-2012, 11:51 AM   #4
The first time I saw a contractor put dry ready mix in a hole I did a double take but sure enough the concrete set up just fine. That stuff sucks up moisture as anyone who has ever kept it in the garage long enough can tell you. With the fact that he put 8 inches of good concrete on top, you should be fine.
I cannot really comment on the freezing issue as every situation is different. I've had to hammer out brand new concrete that froze even in ideal curing situations (burlap, plastic, blankets). It's all in the environment.
Lastly, I would keep a close eye on your contractor. He needs to remember that you are the one paying him and if a plan is in place and he or his guys do not follow it then there is an issue. Something like this may not be a big deal but what if he does his own thing down the road and you fail an inspection adding days and money to the contract?
Hope this helps.
Cheers!
Steve_DIY is offline   Reply With Quote
Old 11-25-2012, 09:13 AM   #5
Concrete & Masonry
Rewards Points: 650
Originally Posted by backwaterdogs View Post
Hey,
NO
Absolutely not.....
jomama45 is offline   Reply With Quote
Footing for new deck posts jl2698 Building & Construction 19 03-29-2012 07:47 PM
Setting the footing height for pergola posts and pavers? blue sky Building & Construction 5 03-14-2012 10:34 PM
Adding posts and beam to floor for aquarium Vincer Building & Construction 4 03-23-2011 02:47 PM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
