Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-15-2012, 06:02 AM   #1
Footers under block walls
Does anyone a copy of the uniform residential code for cinder block walls 6 foot or over?
PAULALAN is offline   Reply With Quote
Old 02-15-2012, 08:18 AM   #2
concretemasonry's Avatar
What are the walls used for? - retaining wall?, privacy wall?, basement wall?
If it for a privacy wall and you are in a southern CA city, there city may have some stardard drawings. For retaining walls and home basements much depends on the soil type and loads.
Check with you local building official for an accurate answer regarding minimum sizes.
Dick
concretemasonry is offline   Reply With Quote
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Waterproof paint on block walls koolie Painting 9 03-23-2011 07:50 PM
basement block walls twrozz Building & Construction 1 06-25-2010 02:49 PM
block walls twrozz Building & Construction 0 06-24-2010 10:26 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
