Footer For Block Partition Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-29-2013, 10:49 PM   #1
Rewards Points: 184
Footer for block partition wall
Hello,
I am having 2 foundation walls of an addition replaced and the new footer has to be 36" deep. If I build an interior block partition wall to separate a crawl space from regular basement, would the footer for this partition wall need to go down 36" deep as well or can I just pour footer right below grade?
The partition wall is only holding up 2 floor joists for 1 story addition, so there's not much weight on it.
Waiting to hear from building inspector (he is on vacation) regarding this, but thought I would check here for some pro opinions in the meantime.
stevekem is offline   Reply With Quote
Old 05-30-2013, 05:47 AM   #2
Rewards Points: 4,578
since crawl spaces are now sealed ( no foundation vents minimize frost chance ), suspect your inspector will allow std depth fnd/footer,,, however he does work for the government & he's there to help what makes sense doesn't necessarily translate to someone who's 1st priority is reinforcing a paid position,,, over the yrs i've found many ' building inspectors ' have been discarded wanna-be contractors
static weight load should be irrelevant to rqmts,,, expect different rqmts between erie & lancaster, easton & stroudsberg, etc
The Following User Says Thank You to stadry For This Useful Post:
stevekem (06-07-2013)
New Partition Wall To Outside Wall TDD99CA Remodeling 2 01-29-2012 03:05 PM
Short Retaining Wall - Footer jkim8520 Landscaping & Lawn Care 3 06-03-2011 10:27 AM
Partition Wall in Garage - Need footer? cmarlo Building & Construction 6 03-30-2011 07:30 AM
Subfloor beyond partition wall hennetina Flooring 1 01-13-2011 08:16 AM
Partition wall supported by subfloor benjamincall Building & Construction 2 06-13-2009 09:47 PM
