Flowable Self Leveling Concrete? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-27-2012, 08:12 AM   #16
Rewards Points: 4,526
diesel fuel unless you're a tree-hugger saran-wrap, too
Old 12-27-2012, 10:49 AM   #17
Rewards Points: 1,600
mop n glo? diesel fuel?
serious?
what about mineral spirit or WD40?
miamicuse is offline   Reply With Quote
Old 12-27-2012, 10:56 AM   #18
Rewards Points: 668
If appearance will be a concern I recommend testing any type of petroleum product release agent before doing the final project. The oils and even paraffin, that I thought would be the ultimate trick I ever thought of, left pocks when the form was removed.
Old 12-27-2012, 11:21 AM   #19
Rewards Points: 3,398
serious?
Mineral spirits doesn't have enough oil left after the refineing process,WD 40 would probably work a little better but i think you would have to lay it on pretty heavy,because it will soak in pretty good.
And Morts answer i'm sure is serious,as is the diesel fuel,because of the wax and oil in the products mentioned.
Canarywood1 is offline   Reply With Quote
Old 12-27-2012, 10:27 PM   #20
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
serious?
Serious. A guy at work uses Mop N Glo on his mixer, and the concrete splatter doesn't stick at all.
Mort is online now   Reply With Quote
Old 12-27-2012, 10:53 PM   #21
Concrete & Masonry
Rewards Points: 520
We've been known to use a highly classified mixture of off-road diesel and heavy hydraulic oil in the past...........
jomama45 is offline   Reply With Quote
Old 12-28-2012, 08:01 AM   #22
back in the day we didn't have the epa OR form/release oils in present day formulations,,, we all knew oil & water didn't mix hence jomama's proprietary elixir or, for us common folk, diesel fuel,,, cheap, reliable, easily sourced, & worked well
Old 01-04-2013, 10:28 PM   #23
Guywithskills
I do like the quickcrete product for overlay. They have dozens of mixes and come with additives, adhesives already in the mix. Dont add too much water... just the right amt is best.
Guywithskills is offline   Reply With Quote
Old 01-05-2013, 06:19 AM   #24
agree w/quikrete opinion however most users will not prep correctly, ' work ' the product correctly ( wtr added / troweling / finishing ), or choose the wrong mtl for the work needed,,, for our o'lay work, we only use bagg'd conc mix mtls from specialty supplier,,, we'd also never buy any epoxies from apron/vest stores
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
leveling concrete subfloors for engineered wood installation robismyname Flooring 0 10-21-2011 02:01 AM
Leveling a concrete slab floor RICHARD HARO Building & Construction 3 03-05-2011 10:30 PM
concrete leveling grainbelt Flooring 5 12-12-2009 09:41 PM
leveling concrete floor Cyrus Flooring 5 10-15-2007 04:26 PM
