"Floating" On Wet Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-22-2013, 05:01 PM   #1
"Floating" on Wet Concrete
I am in the process of building a permanent telescope pier and the pier itself is now done. It is basically a 3' long, 8 inch steel pipe that stands vertically (welded) on a flat steel plate (1 foot square).
The pier will be J-bolted to the pier pad (concrete) and it would be handy to just set the pier/bolts on top of the wet concrete and let the pier itself kind of 'find its home' on top of the pier pad. The pier assembly weighs right at 100 pounds.
What is going to happen when I set this pier assembly on top of wet concrete (100 pounds spread over 1 sq. foot)? Is it going to sink down and down or will it pretty much 'sit on top'? The pier pad itself is basically a cube that is 2.5' x 2.5' x 2.5' (roughly). It will be around 3500 to 4000 psi concrete (and will contain a goodly number of brick sized rocks whose only purpose is to reduce the volume of concrete to be mixed).
Thanks.
dave
DaveLeeNC is offline   Reply With Quote
Old 03-22-2013, 06:29 PM   #2
Rewards Points: 3,346
You want to inbed just the jbolts in the wet concrete,if you try setting the whole thing on the wet concrete,it's going to sink to a certain degree,and may tip one way or the other.
You do have holes drilled into the steel plate,do you not??
Canarywood1 is online now   Reply With Quote
Old 03-22-2013, 06:38 PM   #3
The holes are drilled in the plate (one in each corner). I can set the J bolts with a wood template. I just wasn't looking forward to trying to wrestle a 105 pound pier assembly around trying to line up four holes/hour J bolts.
dave
Old 03-22-2013, 06:40 PM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Just the bolts. If you wait until the concrete has set up enough so the pier won't sink, it won't be wet enough to consolidate around the bolts. And if you put it in there wet, it'll sink.
Just make a cardboard template and use that to locate the bolts.
I hate signatures.
Mort is online now   Reply With Quote
Old 03-22-2013, 06:42 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 348
Can you use a plywood template of the base plate? Attach the J bolts to the plywood and wet set it when you pour the mud- remove the plywood after it cures then set the permanent plate.
Old 03-22-2013, 06:44 PM   #6
Plumber
Rewards Points: 348
A little slow on my posting...
You could use expansion bolts too. Drill them in after the mud cures
Old 03-22-2013, 06:51 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
couldn't you just drill the setup concrete and use epoxy to set your anchors (threaded rods not j-bolts).
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-22-2013, 07:00 PM   #8
[QUOTE=DaveLeeNC;1143252]The holes are drilled in the plate (one in each corner). I can set the J bolts with a wood template. I just wasn't looking forward to trying to wrestle a 105 pound pier assembly around trying to line up four holes/hour J bolts.
As eplumber said is the easiest way,just use a nut on the top and bottom of the j bolts,with the plywood in between.
Old 03-22-2013, 07:21 PM   #9
When all is said and done I guess it is a trade-off between wrestling a 105 pound pier assembly onto J bolts vs. a fair amount of drilling. Not being familiar with the using epoxy in concrete I'll probably go the J bolt/plywood template (wrestling) path.
dave
Old 03-22-2013, 11:03 PM   #10
Msradell's Avatar
Rewards Points: 84
One thing I've learned when doing work like this in industrial situations is to leave one bolt about 1 inch higher. You can catch this one 1st and use it for a pivot point to line up the other 3 (or many more in industrial situations). It makes it much easier to line everything up.
Msradell is offline   Reply With Quote
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 06:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
