Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-26-2012, 09:36 PM   #16
GBrackins's Avatar
floating slab for a one car garage?
Basic Concrete Engineering for Builders by Max Schwartz - http://www.amazon.com/Basic-Concrete.../dp/1572180919
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-26-2012, 10:02 PM   #17
Ok thanks!
CJIII is offline   Reply With Quote
Old 10-29-2012, 08:15 PM   #18
The city requires a 12''x12'' footing since we have bad soil.
Old 10-29-2012, 09:24 PM   #19
You'll have to find out from the city if the footings have to be a seperate pour, or if it can be a monolithic pour,and go according to their requirements,also ask about inspections before pouring.
Canarywood1 is offline   Reply With Quote
Old 10-29-2012, 09:30 PM   #20
Its one pour.
Old 10-29-2012, 09:35 PM   #21
Its one pour.
What about inspection??
Old 10-29-2012, 10:50 PM   #22
Concrete & Masonry
WHat you're looking to build is a grade-beam/thickened-edge/turned-down slab. Extremely common here. As a matter of fact, we just did a 42' x 60' last week.
The forming and bracing is a little more complicated than a typical slab on grade, but otherwise, it's the same animal..............
jomama45 is offline   Reply With Quote
Old 10-30-2012, 12:13 AM   #23
I think it has to be inspected.
Old 10-30-2012, 12:38 PM   #24
Then your good to go,when you get it framed up call for inspection,and after that's done make your pour,just be sure and have plenty of help.
Old 10-30-2012, 05:11 PM   #25
Ok guys thanks for the help.
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 05:24 AM
Garage slab and driveway gap xoix Landscaping & Lawn Care 1 08-29-2010 02:13 PM
enclosing garage, non-load bearing stucco wall - do I need to cut slab & dig footing? eric559 Building & Construction 3 07-07-2010 02:41 AM
