Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-14-2012, 11:13 AM   #1
Float first before working on shower walls?
I'm having a hot mop pan installed. I'd rather not step directly on the hot mop surface for fear of damaging the waterproofing. I'm thinking about floating the mud over the hot mop, and then before tiling using that surface to stand on while I work on the shower walls. I assume that surface will be rock solid.
I did not work the walls because I've been told I cannot install the panels overlapping the hot mop vertical surface (the panels will bend). I want to see the finished pan and see for myself.
darsunt is offline   Reply With Quote
Uneven match between walls and Hardiboard in shower Ocelot Tiling, ceramics, marble 11 10-12-2012 09:26 PM
Cheapest shower walls possible? hoosbekah Kitchen & Bath Remodeling 2 12-09-2011 09:08 PM
Need to replace 34 x 48 shower base (has surround walls inside shower base lip) justplumducky Plumbing 3 09-10-2011 10:59 PM
Grout between new tiled shower walls looks wet. doogie88 Tiling, ceramics, marble 3 10-01-2009 09:05 PM
Busting out my shower tile floor and walls. caliskier Building & Construction 3 03-15-2009 09:59 AM
