#1 |
Flashing Penetrations in preparation for brick.
I posted this in the masonry section and got zero responses. Maybe that was the wrong subforum?
I'm building an addition that will have a full brick veneer exterior (not thin brick). I've found lots of info about flashing windows, [COLOR=blue !important][COLOR=blue !important]doors[/COLOR][/COLOR], ledges for brick but nothing about other penetrations. I'm uncertain about how to prepare the following penetrations before the brick mason arrives: dryer vent, water spigot and A/C lines. I might also be having a propane line put in. That would likely be a 1" black iron pipe through the wall that a regulator will mount to just outside of the brick wall. So how are these pentrations set up, sealed or flashed before the brick masons arrives? |
#2 |
Lines are removed, brick gets put up, once it's dry new holes get drilled for the piping. Silicone caulking goes around pipes.
He should be able to pre cut the brick around where the dryer vent is going if he can see the 4" hole where it was. |
#3 |
You're leaving an inch of space between the brick and the sheathing and planning on drain holes, right? Flashing penetrations in brick walls isn't as sensitive a matter as, say, flashing a window or a chimney because of these measures. You definitely want to try to keep water from penetrating, but if it does (in small amounts), it's not as serious a problem as in other situations. That's why something as simple as caulk is sufficient.
#4 |
Concrete & Masonry
Silicone, caulk, and flashing tape (tape from bottom first & lap over as you go up) are the most direct ways. If you want to do this ahead of time, be sure to confirm with the mason the exact depth of the brick he intends to lay to. This will likely require an actual material sample, as most brick are laid at more than 4" from the backwall.
As mentioned above, if you're building this with a 1" min. airspace with weeps and a way to keep the mortar from damming at the base, these penetrations aren't a huge concern. |
| Display Modes | |
| Flashing penetrations in new construction brick veneer. | jogr | Concrete, Stone & Masonry | 0 | 05-06-2012 12:08 AM |
| Re-roofing: flashing question | prb_nearnorth | Roofing/Siding | 9 | 05-01-2012 12:42 AM |
| Repair or Replace Roof-to-Wall flashing | Learn as i go | Roofing/Siding | 6 | 03-10-2011 04:19 PM |
| Flashing repair | Squash_Pro | Roofing/Siding | 9 | 05-07-2010 01:50 PM |
| Vinyl siding corner posts and flashing on dormers | rhastler | Building & Construction | 7 | 06-05-2009 11:08 PM |
