Flashing Penetrations In New Construction Brick Veneer. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-05-2012, 11:08 PM   #1
Rewards Points: 1,910
Flashing penetrations in new construction brick veneer.
I'm building an addition that will have a full brick veneer exterior (not thin brick). I've found lots of info about flashing windows, doors, ledges for brick but nothing about other penetrations.
I'm uncertain about how to prepare the following penetrations before the brick mason arrives: dryer vent, water spigot and A/C lines. I might also be having a propane line put in. That would likely be a 1" black iron pipe through the wall that a regulator will mount to just outside of the brick wall.
So how are these pentrations set up, sealed or flashed before the brick masons arrives?
new construction no Brick ledge Justbeck101 Building & Construction 25 11-19-2012 01:03 PM
Replacing soffit tucked behind brick veneer. Queequeg152 Building & Construction 3 02-25-2012 07:10 AM
brick veneer with SIP walls tap210 Building & Construction 0 06-14-2011 11:20 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
