#1 |
Fixing the garage side door entrance
The side entrance to my detached garage has some broken foundation blocks. The blocks is joined by the concrete walkway outside the garage.
As you can see from the picture, what's the correct way to remedy this problem? I have no masonry experience but I am pretty handy otherwise and still learning. This is our first home. Thanks. ![]() ![]() ![]()
#2 |
You have a few other issues going on there.
That should have been solid block not hollow used under the door. There was not suppost to be wood under the door, the threshold should have been sitting directly on the concrete in a bed of silicone to keep out water. You never should have remove the aluminum threshold, the whole door frame and all should have been removed instead. Your going to have to remove the whole door now anyway since it's going to have to be lowered and to be able to reattach the threshold. Is that a 1 X used as a bottom plate in those walls? |
#3 | |
Fixing the garage side door entranceQuote:
fyi = pics didn't display for me.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#4 |
That has to be twisting like crazy with that narrow board under it.
#5 | |
So how can I rebuild a new cement support for the new threshold. Do I remove the whole door frame to rebuild it since it's been cut? |
#6 |
Super Moderator
You have a wood door that can be trimmed----I suggest that you break out the crumbling block----addd a temporary wood form and cast a new concrete curb under that door---
I would under cut the jamb first and make the new concrete support an inch or so taller than the existing---then install the thresh hold---trim the door to fit and you are good-- A new adjustable threshold would make cutting the door much more forgiving---
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| Help fixing a garage belt | EdwardGarage | Appliances | 0 | 06-05-2012 12:43 PM |
| How to wire a detached Garage? (w/ Conduit?) | FLintonRice | Electrical | 7 | 06-27-2011 02:08 PM |
| Garage framing rotted, back side dropped 3" | zetti1102 | Building & Construction | 12 | 08-06-2009 09:18 PM |
| Garage Wiring issues | jimmyfloyd | Electrical | 20 | 06-08-2009 03:57 PM |
| Painting the inside side of Tar Paper; unfinished detached garage | cityparkmark | Building & Construction | 8 | 03-03-2008 10:15 AM |
