Fix Wrong Hole While Drilling Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-18-2013, 07:48 PM   #1
fix wrong hole while drilling concrete
First time drilling on concrete, trying to mount a TV wall kit.
I was drilling on concrete, and my drill bit got loose and shaky, and it broke extra concrete. Now I have to fix it so the anchor can correctly fit. Now it just drops as seen on the pic. I'm also attaching a pic of a correct hole.
I have Lanco Spackling, but I don't know if that's too soft to fill the hole.
Can I use this and fill the complete 2" deep hole? How long will I have to wait?
Or is there a better product/method for filling in cement drilled holes gone wrong?
I don't want my TV to fall later on because one of the screws got loose in the spackling fix.
fix wrong hole while drilling concrete-img_3944.jpg   fix wrong hole while drilling concrete-img_3945.jpg
elcool is offline   Reply With Quote
Old 05-18-2013, 08:11 PM   #2
Rewards Points: 13,750
This will fix it.
http://www.loctiteproducts.com/p/13/...l-Concrete.htm
Old 05-19-2013, 09:22 AM   #3
can i drill thru it later?
It won't come out in one big piece?
Old 05-19-2013, 09:36 AM   #4
Try a flat bladed screw driver inside of it and try backing it out.
If it's sticking out slightly you may be able to get a hold of it with a pair of plyers.
Old 05-19-2013, 12:08 PM   #5
what??
Which question are you answering?
Old 05-19-2013, 01:33 PM   #6
Rewards Points: 502
Why not just use epoxy to repair the hole?
tony.g is offline   Reply With Quote
Old 05-19-2013, 01:55 PM   #7
yes, that's what joecaption said.
But I still have questions, like if I can drill thru it later ?
The hole still has to be in the same spot.
I went to the store, they also suggested Hydraulic Cement.
Old 05-19-2013, 02:00 PM   #8
Rewards Points: 502
Epoxy can be drilled. Don't think cement would be a reliable filler for that situation.
Old 05-19-2013, 02:18 PM   #9
Thanks!
Tags
cement , drill , fixing holes , spackling
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
drilling holes in concrete not working, what now? anuvanoob Concrete, Stone & Masonry 17 06-15-2012 08:31 PM
concrete foundation hole sean918 Concrete, Stone & Masonry 2 04-24-2012 06:51 AM
Drilling hole in bathroom sink top GregPearce Plumbing 1 04-11-2011 03:11 PM
