First Timer Installing A Mailbox With Brick Enclosure, Advice Needed Please - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By stadry
Old 12-15-2016, 09:41 AM   #1
Rewards Points: 50
First timer installing a mailbox with brick enclosure, advice needed please
Hello friends,
I hope everyone is doing well. One of my relatives is going has offered to install a new mailbox for us, as the current mailbox and post was damaged by vandals, who stole some copper wire, and I was told that the copper wire hit the wooden post that the old mailbox was on, and even damaged the plastic mailbox.
So, we got a new mailbox, and want to put it in a brick enclosure, nothing fancy, like the images below.
If possible, we would like some colorful bricks or something with appeal.
I am posting some pictures of the location where we want to place the mailbox.
Can someone be so kind and help us know what materials we will need:
1) What types or bricks?
2) Do we need concrete slabs too?
3) I believe we will need concrete, will the fast drying (30-60mins) concrete work?
Any other tips are welcome!
Thank you!!
SAMPLE MAILBOX
LOCATION WHERE WE WANT TO PLACE THE MAILBOX
THE MAILBOX
oxonian is offline   Reply With Quote
Old 12-15-2016, 10:14 AM   #2
Rewards Points: 50
Re: First timer installing a mailbox with brick enclosure, advice needed please
I forgot to add, I am in the Houston, TX area
Old 12-15-2016, 08:06 PM   #3
Rewards Points: 236
you need a solid foundation or wide slab. or that sucker will tilt over. no frost heave, i would make a 3'+ deep hole at least 8" with a wide top = think golf tee.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
oxonian (01-06-2017)
Old 01-05-2017, 04:06 PM   #4
Rewards Points: 50
Thanks. We built a foundation and will wait for the Spring to start building the brick mailbox!
Thank you
Old 01-05-2017, 06:07 PM   #5
Rewards Points: 1,232
The only frost heave in Houston is from sucking down ice cream too fast. I assume it is black gumbo, so your best bet is a drilled pier, but that is not really practical. 4" dthick is fine, extend it beyond the brick 3-4 inches. Take 3' pieces of 1/2" rebar and drive them downward and outward, at least one on each side, leaving a 2" stub into the slab.
Any kind of brick will work, but a cast concrete cap is better as brick ones tend to leak and lead to efflorescence. If you use a brick cap, seal the brick. Consider a curved cap also if of brick.
Fast setting concrete will work, but you still don't want to build on it before at least 24 hours, so it is needless expense.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
oxonian (01-06-2017), stadry (01-06-2017)
Old 01-06-2017, 08:00 AM   #6
Rewards Points: 4,746
t-scar's post is the way to do it imn-s-hfo,,, that way you've got enough of a platform to re-level using a crowbar if/when it does tilt out of plumb
THANKS for posting your ' where ' - makes it much easier to respond w/appropriate information
oxonian likes this.
stadry is online now   Reply With Quote
The Following User Says Thank You to stadry For This Useful Post:
Advice needed on stucco above not over brick. tjfitzgerald Roofing/Siding 0 01-12-2014 08:23 PM
Tuck Pointing - Advice Needed ... indydiy Concrete, Stone & Masonry 7 05-10-2013 06:57 AM
Installing 3 Way Sunsmart Digital Timer Rich Kramer Electrical 7 12-03-2012 02:06 PM
Replacing door on brick wall. Missing lintel! Advice? wad2k Remodeling 2 04-25-2010 06:38 PM
Installing a gas range (advice needed) Krichton Appliances 8 11-24-2006 08:20 PM
