Fireplace Vents, What Are These For And Can I Seal Them Up? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-03-2013, 01:22 PM   #1
New England DIYer
Fireplace vents, what are these for and can I seal them up?
On either side of my firebox in my fireplace, I have these metal doors that go out to vents on the outside. They are horribly drafty and pretty much falling out. I want to know why they originally put them in and if it's OK if I seal them up with brick and mortar? I have never seen them on any other fireplace ever. In case it's applicable I have 2 full flues in this chimney, one on the first floor and one in the walk out basement.
Thanks!
Fireplace vents, what are these for and can I seal them up?-slide-img_3853.jpg-1355369537-1024-768-0-0.jpg   Fireplace vents, what are these for and can I seal them up?-slide-img_3854.jpg-1355369538-1024-768-0-0.jpg   Fireplace vents, what are these for and can I seal them up?-slide-img_3855.jpg-1355369539-1024-768-0-0.jpg   Fireplace vents, what are these for and can I seal them up?-slide-img_3856.jpg-1355369539-1024-768-0-0.jpg   Fireplace vents, what are these for and can I seal them up?-slide-img_3952.jpg-1357239508-1024-768-0-0.jpg
Fireplace vents, what are these for and can I seal them up?-slide-img_3954.jpg-1357239526-1024-768-0-0.jpg
nick26 is offline   Reply With Quote
Old 01-03-2013, 05:28 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
They are for outside air for the fireplace. If they are not there you will pull air from inside your house and out the chimney your inside air will go and you fireplace will be less efficient. Isn't there a flap on the doors inside or outside?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-03-2013, 06:29 PM   #3
Rewards Points: 4,638
do they feed directly into the firebox ?
Old 01-04-2013, 10:44 AM   #4
Rewards Points: 1,232
In some jurisdictions they are required, so check before you seal them up. You should just buy new covers, they will be a little more airtight.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 01-09-2013, 12:41 PM   #5
New England DIYer
Yes you can see where they are positioned here
Fireplace vents, what are these for and can I seal them up?-slide-img_3962.jpg-1357268116-1024-768-0-0.jpg
Old 01-09-2013, 12:46 PM   #6
New England DIYer
That's what I suspected they were for, and I've tried opening and closing them while the fire was going to see if I felt a difference, but I still think they pretty much let cold air into the room even when the fire is going. They certainly counteract an efficiency gain I might get from having them when fire is going to when it's not because of how much air they let in.
They flap is only on the inside, the steel doors you see. On the outside is just a mesh grate.
Old 01-09-2013, 12:49 PM   #7
New England DIYer
Do they make covers that have seals on them or something? I don't see how the metal on metal could seal well regardless of the crappy mortar job around them. I will look into the jurisdiction thing, but my neighbor's fireplace does have them, nor does any other I've seen in this town so I doubt that is an issue.
Old 01-09-2013, 01:04 PM   #8
take the *&%@$%**!#! things out & fill the holes w/firebrick inside & stone outside,,, they're for providing fresh air for combustion rather than pulling air from inside the house which will eventually cause negative air pressure in your very fine home & cause cold air to infiltrate defeating your furnace's work,,, they would be more effective IF you had glass doors that sealed the opening well but its also more $$$,,, fwiw, we rarely have a fire in ours due to the same issue - heat the air inside our home then exhaust it out the chimney
Old 01-09-2013, 07:32 PM   #9
If you do not have them, you are warming the air and exhausting it out the chimney, with the outside air kits you do not do so (glass doors do help through). The amount of air leaking around those vents in good condition is about 1/100 of what you lose through one regular window.
