Fireplace Updating - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-06-2012, 07:59 PM   #1
fireplace updating
My wife and I recently puurchased a home with a terribly off centered 50's fireplace. I amd looking for some ideas on how to go about updatinng the fiireplace. 8i am ffairly sure i will be unable to remove the old brick as i believe this is part of the stcture of the chimney. My trouuble is that therre are four separate "vents" as ii will call them which i am sure i cant cover or can i? It is a wood burning fireplace so i am not sure if these vents are part of heat circulation. Or what their use is for. My expertise is frrsminng and finish work so i am at a loss here any ideas and help welcome thanks
ttoft510 is offline   Reply With Quote
Old 05-06-2012, 08:02 PM   #2
Rewards Points: 13,732
Since you chose to not even post any pictures, not sure how you expect any one to be of much help here.
It would be best to find someone local to check it out. Anyone here is going to be guessing on how to make it look the way you want it to.
Old 05-06-2012, 08:34 PM   #3
Metal Roofing
Rewards Points: 600
You get far more help if you include pics.
You maay neeed too cuut bacck onn thee coffffee also
AndyWRS is offline   Reply With Quote
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Updating Fireplace davediy Remodeling 5 08-15-2011 11:48 PM
Idea For Updating a hanging Fireplace Alcarte Remodeling 1 02-01-2011 06:38 AM
Concrete over brick??? (updating a fireplace) cwelte Remodeling 11 03-28-2010 12:34 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
