Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-17-2012, 06:28 PM   #1
fireplace refacing
I need advice. I've just got a 1950s house and the first thing that you see once you enter is this fireplace 10feet by 4 feet. It looks scary and I am wondering what are my options. What comes to my mind is to
cover it with cement board and put new shiny tile on top of it? I am not planning on using the fireplace. Can I cover the hole too? Should I cap the chimney first or can this be done later? Do I need to call the chimney specialists first or can I survive without it. There is no gas, no electricity that comes to the fireplace. just two doors (in the floow and on top of the hole). I never had a fireplace before, so, sorry for the vague explanation
michigan is offline   Reply With Quote
Old 11-17-2012, 07:14 PM   #2
Super Moderator
fireplace refacing
You don't need cement board----
A couple of options----I'd suggest some wood raised panel work on the left side --along with a new mantle--
And tile or natural stone on the remaining face---
or tile the entire thing----no---that needs to be broken up---
Tile? Use hardened nails with washers to hold wire mesh---(plaster lathe) over the existing stone--skim coat with coarse mortar---then tile---
oh'mike is online now   Reply With Quote
Old 11-17-2012, 07:19 PM   #3
fireplace refacing
i kinda like that fire place. with the right decorating and a few upgrades, i think it could look nice.
ymmv
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 11-17-2012, 08:41 PM   #4
fireplace refacing
Sorry, could you, please, clarify it a little bit for me. Being an armature "do-it-yourselfer" I have just started my learning... How wood raised panel work looks like and what kind of upgrades are possible. Maybe you have some pictures to post for me. Thank you very much!!!
Refacing fireplace w/ Coronado Stone chrysagon200 Concrete, Stone & Masonry 6 05-29-2012 12:53 AM
Suggestions on refacing brick fireplace Lynch Building & Construction 10 10-04-2011 08:33 AM
Refacing a Fireplace VinceA Building & Construction 7 01-03-2011 10:02 AM
Refacing fireplace tusker74 General Discussion 0 08-16-2010 07:49 PM
refacing brick fireplace opieneff Building & Construction 1 04-26-2010 07:47 PM
