Fireplace Question... - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-08-2012, 04:54 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Fireplace question...
I have a tube in the back of my fireplace that extends to the exterior. It looks like it's got a rotating portion on the inside that may allow it to open or close.... It doesn't seem to move though. The last blowing rain we got found the inside of the fireplace a little wet, probably because the thing is wide open. I'm sure i'm losing a good amount of heat out of it.
Should it close? is a fireplace tool supposed to be able to turn it?
Journeyman Plumber
Old 12-08-2012, 05:37 PM   #2
Civil Engineer
Rewards Points: 4,560
That may be a tube for outside air to the fireplace. It can be turned off to keep air out when you are not using the fireplace.
Old 12-08-2012, 09:42 PM   #3
Rewards Points: 13,250
It's for make up air to support the flame instead of creating a negative pressure in the home and sucking air in from the other rooms making them colder.
Old 12-09-2012, 07:58 PM   #4
Doing it myself
Alan's Avatar
It looks like a cylinder inside of a cylinder with holes in it similar to the top of a weber barbecue I guess. I'm assuming that it should rotate then, and should be able to do so with a fireplace tool? I shouldn't really have to put a huge wrench on it... maybe i'll soak it in WD-40.
Journeyman Plumber
Prep work for my fireplace surround question? jpc Painting 11 10-26-2011 05:13 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Question about wood mantle on stone fireplace Daggerhart Remodeling 2 06-15-2008 05:16 PM
Fireplace framing question gobble Building & Construction 2 05-17-2008 11:01 PM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
