Fireplace Masonry - Adding Stone Inside The Firebox - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-02-2012, 08:29 AM   #1
DNB
Post
Fireplace Masonry - Adding stone inside the firebox
The bricks on the inside of my existing fireplace (a standard brick fireplace in my family room) are structurally sound, but look a bit rough. I would like to cover the bottom of the firepit with the same 12 x 12 x 3/8" stone veneer that's on the hearth. Is this advisable? i.e. Will the stone veneer withstand the heat of the fire? Is there a special mortar and grout that should be used? Any other how-to tips? Thanks.
DNB is offline   Reply With Quote
Old 02-03-2012, 04:50 AM   #2
Concrete & Masonry
Rewards Points: 582
Simply put, no, cultured stone will not stand up to the heat period, not to mention it would have adverse effects on the way the fireplace operated by altering the interior dimensions of the firebox. What's wrong with the current brick?
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
DNB (02-06-2012)
Old 02-03-2012, 05:43 AM   #3
Too Short? Cut it Again!
Ditto And I think it would look weird. You could convert to gas logs I suppose. But even then, depending on your firebox, you might crack your stone from heat and cooling.
Old 02-06-2012, 12:24 PM   #4
DNB
Thanks. I agree with all of your sentiments. Much appreciated.
Tags
fireplace , masonry
Fireplace stone veneer, do I really need tar paper? jxr Drywall & Plaster 16 04-19-2017 05:53 PM
Mounting TV to previous stone fireplace installation help canestim Home Theater 11 06-19-2012 08:55 AM
adding wall insulation inside or out? jgreaves General DIY Discussions 1 09-26-2009 05:16 PM
Adding a fireplace upstairs crlove General DIY Discussions 1 03-24-2009 12:54 PM
Adding a gas fireplace BionicWoman Remodeling 7 11-08-2007 12:53 PM
