Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-01-2012, 12:06 PM   #1
PhishPhix's Avatar
Fireplace Mantel Move
So I'm looking at mounting that TV on this fire place. To do so I need to move the mantel down. My concern is this is a gas fire place and I don't want he mantel to be too close to the flame. The mantel piece is solid wood, so I don't think the wood could get to a critical temperature,but honestly I don't know. The wood would be about 6" to 8" from the edge of the fireplace. On a side note will the motar hold a Tv? I know brick is the best solution, but I can patch the mortar when I leave.
PhishPhix is offline   Reply With Quote
Old 11-01-2012, 02:57 PM   #2
You will need to check your local code, but I can almost guarantee that it will require 12"-16".
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-08-2012, 07:59 PM   #3
PhishPhix's Avatar
I've removed the mantle and I'm amazed at how hot the tv is getting. The tv is 14” from the fireplace. Is there a shield or deflector that can block some of this heat? I know the obvious answer is remount the mantle, but that puts the tv uncomfortably high for viewing.
Any suggestions? Thanks
Lennox Superior Fireplace Problem kcrossley2 HVAC 12 11-08-2012 07:39 PM
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 07:46 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
