Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-09-2012, 10:53 PM   #1
Fireplace hearth
I looked for a way to move thread from construction to masonry but did not find option.
We moved into new house (brick ranch house) that has three wood burning fireplaces, and I have a family member that wants to get rid of a fireplace insert. I want to put the fireplace insert in one of the upstair fireplaces. I am concerned about the weight of the fireplace insert though. From the basement I have looked at the bottom of the the hearth which is all brick and it has a concrete slope, I guess to tie into the house brick. I'm not sure how heavy the fireplace insert is but I'm sure it is several hundred pounds.
Do you think that the brick hearth would support the weight of the insert?
marriedmanw is offline   Reply With Quote
Old 10-10-2012, 12:38 PM   #2
sdsester's Avatar
Fireplace hearth
Too hard to tell from here. You had better call a mason or fireplace company to be sure.
sdsester is offline   Reply With Quote
Fireplace hearth weight marriedmanw Building & Construction 0 10-08-2012 06:22 PM
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 11:41 AM
fireplace hearth size beech General Discussion 2 04-15-2012 11:16 PM
Fireplace facelife - needing hearth advice louiejr Building & Construction 4 11-25-2009 06:57 AM
Please Help with Fireplace Hearth Planning BobnSofi Building & Construction 1 02-18-2008 07:26 PM
