Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-11-2012, 10:17 AM   #1
Fireplace - concrete base repair
The concrete base inside my fireplace is cracked and coming up in a few spots. It only appears to be the top inch that is coming up. What is the best way to repair this?
Here is what it looks like.
Fireplace - concrete base repair-image-3827027494.jpg   Fireplace - concrete base repair-image-3036257598.jpg
asbury park is offline   Reply With Quote
Old 02-11-2012, 10:36 AM   #2
BIGRED
That cracking was caused by the original fireplace cement not being allowed to cure long enough. A little moisture trapped in the concrete and the HOT flames generated steam and caused the top coat on the base to spaul. You could just break it all up with a three pound hammer, clean it out real well and pour a new floor, but you should probably get a good brick mason in there to look it over. The brick fireplaces they put in around here use the same fire brick you have on the walls of your fire box, all across the base of the fire box.
Grampa Bud is offline   Reply With Quote
How does one repair small holes in a concrete floor? CnK of NY Flooring 2 08-30-2011 06:59 PM
Repair on Concrete Drive Way Cracks jamiedolan Building & Construction 4 08-17-2010 12:40 PM
Retaining wall concrete base -- how thick? RDS Landscaping & Lawn Care 1 04-23-2010 02:10 PM
Concrete over brick??? (updating a fireplace) cwelte Remodeling 11 03-28-2010 01:34 AM
concrete paver base mande78717 General Discussion 8 06-14-2009 12:38 PM
