Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-26-2012, 12:21 AM   #1
Filling gap in concrete
Hi all,
i have a concrete patio in the back of the backyard (away from house) which was put in by previous homeowner. There is a gap around the perimeter of the concrete pad where it meets a brick trim measuring 8ft long, 0.5 inches wide, 6-8 inches deep.
What can I use to fill the gap?
I've considered:
1. pouring concrete into it, (I've never worked with concrete and I'm afraid of making a mess)
2. polyurethane filler and backer rod (more expensive)
3. concrete sealant (e.g. sika)
Any thoughts?
bernie1971 is offline   Reply With Quote
Old 08-26-2012, 01:21 AM   #2
Pro
I'd go with the urethane sealant and backer rod. Whole job done for 30 bucks and no mess with cementious stuff, no mixing, easy cleanup (if you don't get it all over you :D)I use Vulkem 116 or Sikaflex for that. Both hold up great for stuff like that. I use Vulkem more because I can get so many colors, but I can't get it at HD, so I use Sikaflex when I can't get Vulkem.
Get the right size backer rod so it goes in and stays, but doesn't get all twisted and jammed in there when you install it. If you want it to last the concave shape front and back is important to let it stretch. Use a plastic spoon to tool the top, and keep a rag with some paint thinner on it handy.
smalpierre is offline   Reply With Quote
The Following User Says Thank You to smalpierre For This Useful Post:
bernie1971 (08-26-2012)
Old 08-26-2012, 10:22 AM   #3
Post a picture of the area.
Old 08-26-2012, 09:47 PM   #4
thanks smalpierre.
joecaption, I was goign to take some photos today but the rain spoiled that plan. I'll try to get some pictures soon.
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Filling in large openings in concrete foundation shtoink Building & Construction 10 12-04-2008 05:03 PM
