-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Filling gap in concrete (http://www.diychatroom.com/f105/filling-gap-concrete-154867/)
bernie1971 08-26-2012 12:21 AM
Hi all,
i have a concrete patio in the back of the backyard (away from house) which was put in by previous homeowner. There is a gap around the perimeter of the concrete pad where it meets a brick trim measuring 8ft long, 0.5 inches wide, 6-8 inches deep.
What can I use to fill the gap?
I've considered:
1. pouring concrete into it, (I've never worked with concrete and I'm afraid of making a mess)
2. polyurethane filler and backer rod (more expensive)
3. concrete sealant (e.g. sika)
Any thoughts?
smalpierre 08-26-2012 01:21 AM
I'd go with the urethane sealant and backer rod. Whole job done for 30 bucks and no mess with cementious stuff, no mixing, easy cleanup (if you don't get it all over you :D)I use Vulkem 116 or Sikaflex for that. Both hold up great for stuff like that. I use Vulkem more because I can get so many colors, but I can't get it at HD, so I use Sikaflex when I can't get Vulkem.
Get the right size backer rod so it goes in and stays, but doesn't get all twisted and jammed in there when you install it. If you want it to last the concave shape front and back is important to let it stretch. Use a plastic spoon to tool the top, and keep a rag with some paint thinner on it handy.
joecaption 08-26-2012 10:22 AM
Post a picture of the area.
bernie1971 08-26-2012 09:47 PM
thanks smalpierre.
joecaption, I was goign to take some photos today but the rain spoiled that plan. I'll try to get some pictures soon.
