Filling Concrete Block Cells To Repair Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-29-2012, 04:47 PM   #1
Question
Filling Concrete Block Cells to Repair Wall
I am trying to repair the walls of my 50'lx30'wx12'h garage. There was dirt about 10' up behind the back wall and I have several longitudinal cracks in the back wall and stair cracks in the side wall. I dug out all the dirt behind the walls and the cracks almost all closed up. I want to repair the wall before I install tiebacks into the hillside behind it. I think the best way to do this is fill every few cells with concrete but the 8" block it is built from has 3 cells which are only 2.5" wide. Also the top of the wall is covered with concrete so I have to punch holes into the side of the top block to access the cells. I tried cutting out several cells so I could put rebar down into the cells but with the mortar that squeezed out into the cells I cant get it into them very far. My question is this - can I fill the cell with concrete and have it be stronger than it was originally? I was thinking about making some kind of manifold along the entire wall and pumping concrete into it to fill the cells. Would this work? Any other ideas on how to repair my walls? I am on a very limited budget...
Wildbill9000 is offline   Reply With Quote
Old 08-29-2012, 07:39 PM   #2
Concrete & Masonry
Rewards Points: 530
A couple thoughts here:
- Filling the wall with concrete (grout) will add little to no additional strength to the wall.
- If you can't send a rod through the cells, there's no way you'll get concrete (grout) to completely fill the cell.
- A 12' high wall with 10' of unbalanced fill and constructed with 8" unreinforced block is complete underkill, kind of surprised no one was hurt already from a wall collapse. There must be a decent amount of weight on top of the wall.
- Are you sure there aren't already some pilasters poured inside the wall in the cells? They could easily have failed with the load on the wall.
- As for other options, it's hard to say for sure w/o seeing the conditions. Steel restraints anchored to both the floor and the ceiling "could" be an option. Poured external pilasters on the interior side of the wall could also be an option, but realize that they would need to be relatively substantial, especially at the bottom, and take up some room in the garage.
jomama45 is offline   Reply With Quote
Mounting new load center to concrete block wall. speedster1 Electrical 77 09-09-2012 10:57 AM
Concrete block wall questions Pbody Concrete, Stone & Masonry 1 04-13-2012 10:03 PM
new concrete block wall Ken Mc Painting 1 11-17-2011 10:06 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 11:10 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
