Fill Sewer Outlet Hole In Foundation Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-03-2013, 02:57 PM   #1
Fill Sewer Outlet Hole in Foundation Wall
I have an older home that has a formed opening in the raised foundation wall thru which the sewer line passes. New construction would have cored a hole for this pipe, but this is an opening about 6"below grade, 12" wide and running down to the base of the foundation (or beyond). Exposed pipe is half set in dirt fill with about 10" of open area at the top of the opening.
I'm attempting to stop water intrusion into the crawlspace area. An obvious point is here, where I'm thinking I should better plug this opening.
One thought is to excavate the dirt in the cut beneath the pipe & fill the void with cement. Sewer pipe is cast iron & old. Should I be concerned with wrapping or sleeving (with a split sleeve) filled with expansion foam or ? I am in search of advice as to how others might approach this project.
Catalina Eddy is offline   Reply With Quote
Old 03-03-2013, 03:04 PM   #2
Rewards Points: 13,276
Post a picture so we can see what your seeing.
Old 03-03-2013, 03:41 PM   #3
OK...pic of project/problem as viewed from outside structure looking in towards crawlspace.
Old 03-03-2013, 03:45 PM   #4
If that's old steel pipe do yourself a big favor and replace all it before doing anything.
At some point it will collaps, and by now it's closed up on the inside which will cause clogs.
Old 03-03-2013, 07:26 PM   #5
With all due respect, that still leaves the 'how best to seal the hole' question. I realize that the cast plumbing has reached end of service life. All it takes is time, labor & $$$. It's the latter that I'm short at the moment. Plenty of the former.
Old 03-03-2013, 07:35 PM   #6
MarginallyQualified
Rewards Points: 2,464
concrete fill with mortar parging and then coated with tar
but with 80% of the job open... open the other 20% too
then do the pipe work as well
Old 03-04-2013, 11:48 AM   #7
Thank you both for taking the time to read & respond. Cement & parge it is.
Looking at the cast iron pipe replacement, between excavation out to septic and looking back inside crawlspace there's not much in the way of 'good' pipe surface to join to before hitting the vent stacks. So, I'm looking at virtually complete waste line replacement. Should be a hoot.
Old 03-04-2013, 12:11 PM   #8
MarginallyQualified
and tar below grade
cast iron pipe replacement, between excavation out to septic...
Not ALL of the pipe... just what you're about to encase in 'crete
and what is reasonably accessible under the house the (10 feet or so )
If that exposes other problems farther down the line? deal with it.
Old 03-04-2013, 02:19 PM   #9
Originally Posted by TarheelTerp View Post
and tar below grade
Roger that.
And this'll have to migrate over to the plumbing forum at this point. Problem with replacing a section of this line is that the whole thing has surface corrosion to the point that I doubt that I can grind or otherwise smooth the mating surface in order to get a Fernco coupler to hold tight. So..that's why I'm considering replacement of the whole line, or at least as much as feasible w/o tearing out walls.
24" crawl space. If I can find the $$$ I might as well knock it out now. Ain't getting any younger. Five more years & I might not be able to get into that crawlspace. Amazing what you can find that needs doing when you are just trying to paint a house.
Thanks again.
Old 03-04-2013, 04:16 PM   #10
PVC pipe is cheap compaired to the hassle on having that drain fail.
Old 03-04-2013, 06:20 PM   #11
MarginallyQualified
Problem with replacing a section of this line is that the whole thing has surface corrosion...
The surface rust is the least of the problems.
Either leave it be until you're psychologically prepared to deal...
or are at some point forced to deal... or do it right (now).
Just don't encase the old pipe.
Why aren't foundation wall duct openings wider?! joshoc Building & Construction 20 08-04-2012 11:01 PM
Need of reinforcement of foundation wall due to HVAC ductwork hole? whoopus Building & Construction 1 07-18-2012 12:50 PM
Why aren't foundation wall duct openings wider?! joshoc HVAC 5 07-09-2012 07:33 PM
Cutting into foundation wall to install entry door. notenoughtime Building & Construction 7 08-19-2009 03:13 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
