Fill An Old Cistern With Concrete? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-22-2012, 09:16 PM   #16
Rewards Points: 960
I think it would be a shame to fill that hole.
There is some guy around who was posting about putting a swimming pool or something in his basement. He had a lot of ideas, then he surfaced with some other questions about some other crazy deal.
Save that hole for someone like him.
Another thing you could do is go out on the interstate during a snowstorm and pick up people who have broken down and what not and throw them down in there and keep them there.
cleveman is offline   Reply With Quote
Old 01-01-2013, 05:58 PM   #17
Hi all,
Posting a few pictures of the cistern. Thanks again for the info and advice, much appreciated.
Happy 2013,
Earl
Fill an old cistern with concrete?-cistern-west.jpg   Fill an old cistern with concrete?-cistern-view-down.jpg   Fill an old cistern with concrete?-cistern-view-down-2.jpg   Fill an old cistern with concrete?-cistern-inlet-ledge.jpg
earlieq is offline   Reply With Quote
Old 01-01-2013, 06:39 PM   #18
Rewards Points: 240
that is cool ! i would keep it & put a joist floor over it.
Fix'n it is offline   Reply With Quote
Old 01-04-2013, 08:32 PM   #19
Guywithskills
Stone is the way to go. There is a backfill slurry, called 1/2 or 1 sack specifically for trenches typically in roadways where they do not want to have it settle or have to do compaction, this stuff runs $65/yd and you still have to get it into the hole. keep the cement truck off of sidewalks, curbs, drives and away from basements... these trucks carry up to 50,000 lbs of concrete, not including the truck weight. they move slabs like you would not believe. They move inches, not just crack. I've seen them pushed slabs down 4" on "dry" ground.
For me, a load of ABC or some areas call it modified... dumped at the curb, a few wheel barrels and several friends or teenage boys and on with it. Poor it later with premix Home depot 5000lb rate. or pay the $500 minimum for a truck to bring out. Some time there are short load trucks in an area that specialize, they are still not cheap.
Guywithskills is offline   Reply With Quote
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 09:03 AM
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 12:34 PM
What to use to fill in concrete joints to reduce weeds? Skram Building & Construction 13 06-27-2011 05:01 PM
How to fill in gaps under concrete form boards spaceman spif Building & Construction 4 11-23-2010 10:18 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
