Fill Concrete Wall Before Tiling - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-25-2013, 10:16 AM   #1
Rewards Points: 29
Fill concrete wall before tiling
Hi guys,
Removing tile from a dated bathroom. Behind the tile it looks like 2 "layers" of concrete. Any suggestions on what to use and how to fill the void. I obviously need to get it all flush for the new tile. Thanks so much for all your help!
Marcus
Fill concrete wall before tiling-image-2217189170.jpg   Fill concrete wall before tiling-image-2400112391.jpg   Fill concrete wall before tiling-image-2536329095.jpg
sundh is offline   Reply With Quote
Old 05-25-2013, 04:40 PM   #2
DIY staff
Rewards Points: 7,174
That old cement scratch coat is to far gone to save.
You need to remove the mesh and cement back to the studs and furr the wall out so you can install modern Durrock or other cement board.---Consider waterproofing the surface of the new board with a paint on membrane like Redguard or Hydroban.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ddawg16 (05-25-2013)
Old 05-25-2013, 04:48 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
Follow Mike's advice. It will actually take you about as much time to demo and fur that out as it would to try and patch it. And you will end up with a better result.
You really appreciate it when you start tiling. Quickest way to find out something is not flat is to try and put tile on it.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
oh'mike (05-25-2013)
Filling Concrete Block Cells to Repair Wall Wildbill9000 Concrete, Stone & Masonry 1 08-29-2012 06:39 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 10:10 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
do not use concrete filler to fill stones... KUIPORNG Landscaping & Lawn Care 4 08-29-2008 04:16 PM
