Fastening A Subfloor To Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-12-2012, 11:22 PM   #1
Rewards Points: 77
Fastening a subfloor to concrete
Hello,
I am about to fasten plywood to 1/3 strapping (styrofoam between strapping) overtop of a plastic 'dimpled' membrane to a concrete slab floor.
My question is what fastener to use? masonry nails? Tapcon screws? Anchors? Masonry nals with a piece of solder wire?
To follow up that question is the process in which I perform this activity. Hammer drill, masonry drill bit...
Any advice on this is GREATLY appreciated.
shorteared is offline   Reply With Quote
Old 03-12-2012, 11:36 PM   #2
Rewards Points: 12,794
I've had the best luck with the holding power if a Tap Con screw. I predrill the wood then hole it up to the wall and drill through the wall with a Bosch Bulldog hammer drill. I drive the screws with a Ryobi impact driver.
Personaly I install the foam board to the wall first with constrution adhesive and install the slats after. I use strips of Advantech not 1 X 4's because they tend to split when the screws go in.
I install a 6" wide piece along the bottom first, 1/2" up off the floor, then a 4" wide piece across the top, last I install the slats every 16".
The bottom piece is so there's a good place to install the baseboard, and up of the floor so it will not wick up water.
Old 03-13-2012, 10:03 PM   #3
Rewards Points: 77
Thanks for the reply,
Are you using a rotary hammer drill? I have heard that they differ from "a normal hammer drill"
Also, how far into the concrete should I go? I appreciate the help!
Tags
basement , concrete , nail , screw , subfloor
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
