Fasteners To Support Vine On Block Wall? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-04-2012, 11:08 AM   #1
Rewards Points: 682
Fasteners to support vine on block wall?
What kind of fasteners would you use to attach wire or trellis to a block wall, to support a bougainvillea vine? I use tapcon for concrete, but that seems like overkill for a block wall. Is there a simpler fastener you guys use for block wall?
darsunt is offline   Reply With Quote
Old 05-04-2012, 01:10 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
overkill?you drill a hole and drive a screw..i don't understand
Tom Struble is offline   Reply With Quote
Old 05-04-2012, 01:14 PM   #3
Rewards Points: 682
It's just going to hold up some wires or light wood frame for the bougainvillea. Also I heard cinder block is a lot weaker than concrete.
Old 05-04-2012, 10:57 PM   #4
Rewards Points: 940
Put some plastic or lead anchors in the joints.
cleveman is offline   Reply With Quote
Old 05-04-2012, 11:10 PM   #5
Too Short? Cut it Again!
I would definitely use a masonry bit and plunk some anchors in. Screw whatever into them with silicone to prevent elctrolytic reactions. Stretch your mesh and protect any unmatched metals with plastic washers or something. Keep the mesh to start from too close to the ground.
Enjoy the display of flowers for years.
Framing a wood studded wall against a concrete block wall miamicuse Remodeling 22 01-21-2014 10:20 AM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 11:10 AM
Garage CMU partial wall - shifted block ChrisJJ Building & Construction 9 04-01-2011 01:27 PM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
