Exterior Ventilation Hole - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-07-2012, 04:25 PM   #1
Exterior ventilation hole
Hi,
need contact info to have exterior hole cut on the brick to the interior of a kitchen in order to install an exhaust fan. Need some one who is able to cu t 5 or 6 inch hole without breaking the brick .
DMCNERNEY is offline   Reply With Quote
Old 08-07-2012, 04:28 PM   #2
DIY staff
Rewards Points: 7,174
What country are you from?
Old 08-07-2012, 04:32 PM   #3
CAnada
Old 08-07-2012, 04:57 PM   #4
DIY staff
What you will want to do is find a 'core drilling' company---
Look under 'concrete cutting' or 'core drilling' in the local yellow pages,
Also--any concrete contractor will know of a good one as concrete companies use this service frequently--along with many plumbers.
The machines are expensive .
If you don't need a perfect diamond cut hole----the brick could be drilled with a series of holes using an ordinary masonry bit in a hammer drill---and the center chipped out with a chisel.
Old 08-08-2012, 03:54 PM   #5
Rewards Points: 152
Drill many holes and chisel out. Easy Easy job. The exhaust vent will have a face cover which will hide the rough edge brick hole. You could also use a grinder with a diamond blade to cut the brick. Drawl your circle, drill the perimeter all the way around. Grind a "X" inside the circle hammer-n-chisel to liking. Voila. (No need for core drilling.)
Or
You can rent a core drill and a 6" bit for around $200 1/2 day.
GL
TRUEPRO is offline   Reply With Quote
Old 08-08-2012, 08:54 PM   #6
DIY staff
GL
Those drills are heavy---we used to hang them off a fork lift or use a hoist to suspend them for horizontal coring---Might be a challenge---
Old 08-12-2012, 07:19 PM   #7
Rewards Points: 152
I believe it...didnt really take that in to consideration a DIYer might have a challenge!!
Repair Small Hole in Vinyl Siding Silkcityflorida General DIY Discussions 12 04-08-2013 03:34 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 11:55 AM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 02:52 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
