Exterior Concrete Leveling Compound - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-01-2012, 01:27 AM   #1
Rewards Points: 31
Exterior concrete leveling compound
I have a small concrete front porch slab (approx 5'x7') that I need to level and wanted to know what exterior leveling compound to use? The compound would be no more that 3/4" at its thickest. I just need a product that will hold up to the Canadian climate and not crack or deteriorate over time, I am not concerend with the finish as a side walk finish if any will do.
Hardwood Head is offline   Reply With Quote
Old 11-01-2012, 08:03 AM   #2
Rewards Points: 3,130
I don't think any slab should be perfectly level. You need some minimum slope so rainwater will run off.
Old 11-01-2012, 08:44 AM   #3
Rewards Points: 13,296
Anything that thin is just going to crack.
Old 11-01-2012, 09:34 AM   #4
Architect
Rewards Points: 150
Agreed.
No topical solution will be long lasting if the maximum thickness is only 3/4" or less.
Are the stairs sinking or falling away from the house? Where they originally poured with some slope?
There might be other solutions to the problem if you provide more information.
jcarlilesiu is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
starting floor project with clean slate by using leveling compound robismyname Flooring 1 10-07-2011 01:53 PM
self leveling compound mmhendrie Flooring 2 09-01-2010 08:39 PM
floor leveling compound geraldS Flooring 4 03-01-2009 09:20 AM
