-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Exterior concrete leveling compound (http://www.diychatroom.com/f105/exterior-concrete-leveling-compound-161801/)
Hardwood Head 11-01-2012 12:27 AM
I have a small concrete front porch slab (approx 5'x7') that I need to level and wanted to know what exterior leveling compound to use? The compound would be no more that 3/4" at its thickest. I just need a product that will hold up to the Canadian climate and not crack or deteriorate over time, I am not concerend with the finish as a side walk finish if any will do.
md2lgyk 11-01-2012 07:03 AM
I don't think any slab should be perfectly level. You need some minimum slope so rainwater will run off.
joecaption 11-01-2012 07:44 AM
Anything that thin is just going to crack.
jcarlilesiu 11-01-2012 08:34 AM
Agreed.
No topical solution will be long lasting if the maximum thickness is only 3/4" or less.
Are the stairs sinking or falling away from the house? Where they originally poured with some slope?
There might be other solutions to the problem if you provide more information.
