Extending Concrete Pool Deck - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-16-2014, 05:21 AM   #1
extending concrete pool deck
I'm in the process of extending a concrete pool deck towards a slope. I have a few questions.
My first dilemma is trying to decide whether to build a traditional cinder block retaining wall or use gabions to address the slope before pouring the slab to extend the pool deck.
If I use gabions is it ok to pour a slab on top of it?
If I go the cinder block route, should the slab sit inside of or on top of the retaining wall. Also should the retaining wall have drainage even though it will be covered by a slab?
fatboyelroy is offline   Reply With Quote
Old 06-16-2014, 11:18 AM   #2
Rewards Points: 3,342
While I've never seen a slab on top of a gabion, that's not to say it isn't done but I think an engineer would be the one to answer your question as opposed to a layman on a DIY forum, there is one here Daniel Holzman that may see your question and jump in.
Canarywood1 is online now   Reply With Quote
Old 06-16-2014, 10:43 PM   #3
Msradell's Avatar
Rewards Points: 82
That doesn't look like enough elevation drop require the use of gabions. It looks like the elevation change is <2'. If that's the case I would pour a stub wall to the frost line depth and then pour the slab onto the top of it.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Old 06-17-2014, 12:28 AM   #4
No frost line to worry about here in Costa Rica . Are there any advantages to pouring a stub wall vs a cinder block wall?
Old 06-17-2014, 10:56 PM   #5
Msradell's Avatar
Rewards Points: 82
A stub wall will be much more stable in the long run and will be much better at resisting the pressure of the fill pressing it outward! If you use cinderblocks you are still going to have to fill them and put in a foundation to stabilize them.
Replaceing 6" x 6" post on a settleing pool deck. Queequeg152 Building & Construction 7 08-21-2012 11:29 AM
Spots on new concrete pool deck trenco Building & Construction 4 11-29-2011 12:58 PM
Ideas for deck over concrete patio and beyond-pics- bdobs General DIY Discussions 11 10-22-2010 09:50 AM
Is it SAFE not to use deck post concrete anchors? z_zk_z Building & Construction 3 06-28-2010 10:35 PM
Sagging concrete pool deck Immolate General DIY Discussions 1 06-11-2008 10:16 PM
