Exposed Aggregate Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-09-2013, 08:12 PM   #1
jkk
Rewards Points: 233
I have 2 pieces of step that have broken off. What kind of epoxy can I use to cosmetically repair this (just want to glue these in place). This is not a high visibility area.
Thanks.
jkk is offline   Reply With Quote
Old 04-09-2013, 08:58 PM   #2
Rewards Points: 12,878
Back up and take another picture.
No form of epoxy is going to make that look right or hold up by the looks of it.
Old 04-10-2013, 08:45 PM   #3
Rewards Points: 4,454
we use akemi,,, you may have to mix it stiff to get it to hold - get the vertical grade,,, crushing up some conc to dust the wet epoxy is a help to disguising the repair,,, pebbles, too - press into epoxy when wet
prop up the repr whilst the epoxy cures
attn: Tscarborough, Hurricane Sandy, basement repair, point, parge, insulate beachstreet Building & Construction 4 02-25-2013 11:46 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
partially exposed rafters rtoni Building & Construction 1 08-13-2008 05:45 PM
Exposed Wood Beam Ceiling repair - help needed abiseid Carpentry 6 01-04-2008 10:01 PM
Losing aggregate from asphalt shingle ridge bkspero Roofing/Siding 8 07-19-2007 10:40 PM
