Expansion Joints Needed In New Driveway? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree7Likes
Old 10-13-2016, 03:25 PM   #1
Rewards Points: 206
Question
Expansion joints needed in new driveway?
Our existing driveway will be removed and replaced, including extra concrete on one side.
Control joints will be cut into the new driveway in a pattern of 8' (or smaller) squares.
We probably need an expansion joint at the street end (1).
Do we need expansion joints where the driveway meets the brick or the garage slab?
The soil is red clay. We are 50 miles south of the Tennessee line in Alabama.
Expansion joints needed in new driveway?-one.jpg   Expansion joints needed in new driveway?-two.jpg   Expansion joints needed in new driveway?-three.jpg   Expansion joints needed in new driveway?-four.jpg   Expansion joints needed in new driveway?-five.jpg
John_W is offline   Reply With Quote
Old 10-13-2016, 04:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,358
Re: Expansion joints needed in new driveway?
Ayuh,.... I donno 'bout at the street, but most assuredly, ya want expansion joints up next to the brick work, 'n across the face of the house slab,...
John_W and ZTMAN like this.
The Following User Says Thank You to Bondo For This Useful Post:
John_W (10-13-2016)
Old 10-13-2016, 05:30 PM   #3
Rewards Points: 206
Any suggestions on the expansion material to use and how thick it should be?
Old 10-13-2016, 08:39 PM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
Can't really tell, is that a sidewalk or the driveway apron? If a sidewalk, yes to an expansion joint. Not necessary if it's against asphalt.
John_W likes this.
I hate signatures.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
John_W (10-13-2016)
Old 10-13-2016, 09:58 PM   #5
Rewards Points: 206
Its the driveway apron. The apron is against the asphalt. Sometimes people here don't replace the apron. Most do.
Old 10-13-2016, 10:06 PM   #6
Msradell's Avatar
Rewards Points: 210
I'm not sure what you can do to change it but the 1st step of that stairway you showed was the concrete butted up against it definitely does not meet code. All the steps need to be the same height within 3/8 of an inch in that 1st 1 is obviously much much lower than any of the others.
John_W likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
John_W (10-14-2016)
Old 10-14-2016, 08:18 AM   #7
Rewards Points: 206
Yeah, you are right. Not an easy fix either.
What also surprises me is that there are no expansion joints between the driveway and the brick or garage slab - and no apparent harm done in over 50 years. Was that luck?
Old 10-14-2016, 12:18 PM   #8
Pterosaur's Avatar
Rewards Points: 62
Free if you want it, private message me if you want it john, its 4 inches and i cant return it. was going to use it but decided not to.
Pterosaur is offline   Reply With Quote
The Following User Says Thank You to Pterosaur For This Useful Post:
John_W (10-14-2016)
Old 10-14-2016, 12:25 PM   #9
Pterosaur's Avatar
Rewards Points: 62
almost 50 feet
Old 10-14-2016, 12:30 PM   #10
Pterosaur's Avatar
Rewards Points: 62
Here is the product description for the product by the way.
"The reflected closed cell foam expansion joint is the solution to your concrete placement needs. It is durable, lightweight and flexible enough to shape to contours. The product includes a 0.5 in. x 0.5 in. tear-off strip for applications where caulking is planned.
  • Lightweight - over 11 times lighter than traditional products
  • Sturdy - will not prematurely break during job site handling
  • Resistant to moisture - virtually zero water absorption
  • Termite resistant - does not facilitate destructive termites
  • Recyclable - foam is made of recyclable resins
  • Environmentally-friendly - material is CFC and HCFC-free
  • Temperature-friendly - excellent range for cold or hot climates
  • Reusable - tear-off strip can be reused as a backer rod
  • Sealant friendly - works with a variety of common sealants"
Old 10-14-2016, 01:04 PM   #11
Rewards Points: 3,628
A fibre expansion joint, a 1/2" thick will do.
John_W likes this.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
John_W (10-14-2016)
Old 10-14-2016, 05:24 PM   #12
Rewards Points: 206
Is joint sealant needed, on top of the fibre, to protect from water infiltration and weathering?
Old 10-15-2016, 09:58 AM   #13
No, it's asphalt inpregnated.
Old 10-17-2016, 04:32 AM   #14
Rewards Points: 4,648
exp jnt against any structure even if its a concrete loading dock/ramp,,, conc expands during heat & shrinks in cold as any solid,,, sounds as if your jnt pattern's well thought-out,,, bear in mind the little side pieces will have a different contraction joint spacing to prevent random cracking,,, we'd do the same in atl
John_W likes this.
The Following User Says Thank You to stadry For This Useful Post:
John_W (10-17-2016)
Old 10-17-2016, 07:25 AM   #15
Rewards Points: 206
Are you talking about control joints for the side pieces, to prevent random cracks?
For control joints I'm following: http://www.concretenetwork.com/concr...troljoints.htm
Concrete driveway sand washout/expansion joint repair sk8z Concrete, Stone & Masonry 1 06-27-2012 10:31 AM
Driveway sinking & cracking help needed, please? Unicornz0 Building & Construction 6 05-22-2012 06:50 PM
asphalt/concrete joints and a channel drain wolderiii Building & Construction 0 08-26-2011 10:02 AM
Pavement expansion joints .......expanding! RetiredSoldier Building & Construction 11 07-18-2011 12:12 AM
Expansion joints for electrical conduit brjl Electrical 17 04-19-2011 03:16 AM
