Expansion Joint Sealeant - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-29-2013, 10:42 AM   #1
hboogz's Avatar
Rewards Points: 97
All --
I need to repair some old self-leveling sealeant that's come loose and in some parts have been removed entirely on my sidewalk and around a few other areas. I'm in the norteast, so the winters are cold and summers are hot. Which product and method do you recommend to fill in the joint expansion joints?? Looking for a definitive guide and good product on getting this done. Thanks!
hboogz is offline   Reply With Quote
Old 09-02-2013, 05:48 AM   #2
Rewards Points: 4,534
self-leveling depends ( more than non-sag does ) on clean sidewalls for proper adhesion,,, its also important sealant has proper depth:width ratio,,, we also have temp caused exp & contr just no frost heaves
we used ge 100% silicone for the 1st NYSDOT conc pvmt jnt sealing,,, we also used polysulfide but now i'd suggest either 100% silicone or polyurethane - use the non-sag version - clean sidewalls properly - ' tool ' sufficiently
Recurring ceiling crack - Drywall Expansion Joint? kuj0317 Drywall & Plaster 5 11-26-2012 12:27 AM
Concrete Driveway and expansion joint segal Concrete, Stone & Masonry 14 08-30-2012 10:25 AM
Concrete Path Against Foundation without Expansion Joint Baoh Building & Construction 2 11-20-2011 04:14 AM
Expansion joint john4153 Plumbing 0 10-05-2011 08:51 PM
Tiling over expansion joint - confused jkr77 Flooring 20 04-12-2011 04:56 PM
