Excavating And Settling The Ground - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-14-2013, 01:27 PM   #1
Excavating and settling the ground
Hello all,
I will be excavating about 4 feet deep (where my foundation is) to do waterproofing of the walls and reinstalling the weeping tile. While I am doing this, I want to redo the driveway landscaping stones, I know that the soil that I have excavated will settle over time but is there a way I can settle all that soil using a compactor so that I can do the landscaping at the same time. I will follow the 12" rule for the patio stone, I am concerned about everything underneath it, if I just compact all that, should I be okay?
Thanks for the help!!
indep is offline   Reply With Quote
Old 01-14-2013, 02:24 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,.... If you fill the hole with 4" lifts, 'n mechanically compact each lift, you should see very little settlement...
Old 01-15-2013, 09:01 AM   #3
Rewards Points: 4,534
where is the discharge now ( you call it ' weeping tile ' - the old orangeburg clay pipe - we use hdpe pipe - less $ & faster ),,, IF nodischarge ( gravity/mechanical ), you're building an underground dry well / retention pond
conc bsmt walls resist lateral mechanical compaction force waves,,, IF its block, foot compaction in 2" lifts works much better
