-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Excavating and settling the ground (http://www.diychatroom.com/f105/excavating-settling-ground-169100/)
indep 01-14-2013 12:27 PM
Hello all,
I will be excavating about 4 feet deep (where my foundation is) to do waterproofing of the walls and reinstalling the weeping tile. While I am doing this, I want to redo the driveway landscaping stones, I know that the soil that I have excavated will settle over time but is there a way I can settle all that soil using a compactor so that I can do the landscaping at the same time. I will follow the 12" rule for the patio stone, I am concerned about everything underneath it, if I just compact all that, should I be okay?
Thanks for the help!!
Bondo 01-14-2013 01:24 PM
Ayuh,.... If you fill the hole with 4" lifts, 'n mechanically compact each lift, you should see very little settlement...
stadry 01-15-2013 08:01 AM
where is the discharge now ( you call it ' weeping tile ' - the old orangeburg clay pipe - we use hdpe pipe - less $ & faster ),,, IF nodischarge ( gravity/mechanical ), you're building an underground dry well / retention pond
conc bsmt walls resist lateral mechanical compaction force waves,,, IF its block, foot compaction in 2" lifts works much better :yes:
